This morning two of my nodes went offline an hour or two apart from one another for an unknown reason… Are there any stored logs to find out what happened?
Also you can open your storagenode.log with an txt editor ( like notepad or notepad++)
If the nodes are running again, you can search for fatal in those logs.
if the logfiles grew to big, Serveral GB are possible, stop the nodes, delete the logfiles and set the loglevel to error or fatal in the config.yaml.
