Unable to Connect to Storj Using Android App - Need Help
Hello,
I am trying to connect to Storj using the Android app “FolderSync” (Lite version: link-1, Full version: link-2). However, despite checking my access key and S3 credentials, I am unable to connect to Storj using this app.
I am using ap1 and have attached some screenshots of the available regions and the error I am encountering. Could someone please help me troubleshoot this issue?
Thank you in advance for your assistance.
Screenshot 2023-03-20 140825
Screenshot 2023-03-20 141813
Hello @Syafa,
You need to select S3 compatible and provide your S3 credentials and Endpoint (important!). Endpoint should be https://gateway.storjshare.io.
Storj DCS doesn’t have regions, it’s globally available, so you may specify anything there or leave it empty. The main option is Endpoint, without it the application will try to connect to Amazon instead of Storj DCS.
Thanks for the reply, I found a way to connect to Storj after I remove the https://
