A friend of mine is trying to run a node is receiving this error when trying to run the node:
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
container-station/docker: Error response from daemon: driver failed programming external connectivity on endpoint storagenode (1
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx): Bind for 0.0.0.0:28967 failed: port is already allocated.
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS
NAMES
xxxxxxxxxxx storjlabs/storagenode:latest "/entrypoint" 3 minutes ago Created
storag
The commands run:
docker run --rm -e SETUP="true" \
--mount type=bind,source="/root/.local/share/storj/identity/storagenode",destination=/app/identity \
--mount type=bind,source="/share/Storj-one-node",destination=/app/config \
-p 28967:28967 \
-p 14002:14002 \
-e WALLET="0xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" \
-e EMAIL="xxx@domain.tld" \
-e ADDRESS="xxx.ddns.net:28967" \
-e STORAGE="3400GB" \
