fmas@delta:~$ docker logs --tail 100 storagenode
goroutine 14 [select]:
database/sql.(*DB).connectionResetter(0xc0001c43c0, 0x104a820, 0xc00007bf00)
/usr/local/go/src/database/sql/sql.go:1065 +0xfb
created by database/sql.OpenDB
/usr/local/go/src/database/sql/sql.go:723 +0x193
2019-09-27T20:37:43.708Z INFO Configuration loaded from: /app/config/config.yaml
2019-09-27T20:37:43.749Z INFO Operator email:
2019-09-27T20:37:43.749Z INFO operator wallet:
unexpected fault address 0x7f0e59d7f000
fatal error: fault
[signal SIGBUS: bus error code=0x2 addr=0x7f0e59d7f000 pc=0xb174f1]
goroutine 1 [running]:
runtime.throw(0xef76d1, 0x5)
/usr/local/go/src/runtime/panic.go:774 +0x72 fp=0xc00016c998 sp=0xc00016c968 pc=0x4335e2
runtime.sigpanic()
/usr/local/go/src/runtime/signal_unix.go:391 +0x455 fp=0xc00016c9c8 sp=0xc00016c998 pc=0x448e35
github.com/boltdb/bolt.(*DB).page(…)
/go/pkg/mod/github.com/boltdb/bolt@v1.3.1/db.go:796
github.com/boltdb/bolt.(*DB).mmap(0xc00000c960, 0x0, 0x0, 0x0)
/go/pkg/mod/github.com/boltdb/bolt@v1.3.1/db.go:282 +0x251 fp=0xc00016ca88 sp=0xc00016c9c8 pc=0xb174f1
github.com/boltdb/bolt.Open(0xc000038727, 0x15, 0x180, 0xc00016cb98, 0xc0001b03c0, 0xc000190c80, 0xc00016cbb0)
/go/pkg/mod/github.com/boltdb/bolt@v1.3.1/db.go:230 +0x2ae fp=0xc00016cb50 sp=0xc00016ca88 pc=0xb16ebe
storj.io/storj/storage/boltdb.New(0xc000038727, 0x15, 0xefd33b, 0xb, 0x2, 0x2, 0xc0003313a0)
/go/src/storj.io/storj/storage/boltdb/client.go:41 +0x7f fp=0xc00016cc30 sp=0xc00016cb50 pc=0xb2732f
storj.io/storj/pkg/revocation.newDBBolt(0xc000038727, 0x15, 0xc000038720, 0x4, 0xc000038727)
/go/src/storj.io/storj/pkg/revocation/common.go:52 +0x4e fp=0xc00016cc80 sp=0xc00016cc30 pc=0xb73dbe
storj.io/storj/pkg/revocation.NewDB(0xc000038720, 0x1c, 0xe, 0xc0002e18c0, 0x1c)
/go/src/storj.io/storj/pkg/revocation/common.go:34 +0x1bf fp=0xc00016cce0 sp=0xc00016cc80 pc=0xb73caf
storj.io/storj/pkg/revocation.NewDBFromCfg(...)
/go/src/storj.io/storj/pkg/revocation/common.go:21
main.cmdRun(0x1888ae0, 0xc0001d24e0, 0x0, 0xd, 0x0, 0x0)
/go/src/storj.io/storj/cmd/storagenode/main.go:143 +0x521 fp=0xc00016d280 sp=0xc00016cce0 pc=0xc29711
storj.io/storj/pkg/process.cleanup.func1.2(0x104aae0, 0xc0001cbcc0)
/go/src/storj.io/storj/pkg/process/exec_conf.go:264 +0x13b fp=0xc00016d318 sp=0xc00016d280 pc=0xaec53b
storj.io/storj/pkg/process.cleanup.func1(0x1888ae0, 0xc0001d24e0, 0x0, 0xd, 0x0, 0x0)
/go/src/storj.io/storj/pkg/process/exec_conf.go:282 +0x17df fp=0xc00016dd50 sp=0xc00016d318 pc=0xaeddcf
github.com/spf13/cobra.(*Command).execute(0x1888ae0, 0xc0001d2340, 0xd, 0xd, 0x1888ae0, 0xc0001d2340)
/go/pkg/mod/github.com/spf13/cobra@v0.0.3/command.go:762 +0x460 fp=0xc00016de28 sp=0xc00016dd50 pc=0x62cbb0
github.com/spf13/cobra.(*Command).ExecuteC(0x1888880, 0xc00007c180, 0x1, 0x1)
/go/pkg/mod/github.com/spf13/cobra@v0.0.3/command.go:852 +0x2ea fp=0xc00016def8 sp=0xc00016de28 pc=0x62d5ea
github.com/spf13/cobra.(*Command).Execute(…)
/go/pkg/mod/github.com/spf13/cobra@v0.0.3/command.go:800
storj.io/storj/pkg/process.Exec(0x1888880)
/go/src/storj.io/storj/pkg/process/exec_conf.go:73 +0x17f fp=0xc00016df48 sp=0xc00016def8 pc=0xae8f0f
main.main()
/go/src/storj.io/storj/cmd/storagenode/main.go:296 +0x2d fp=0xc00016df60 sp=0xc00016df48 pc=0xc2af8d
runtime.main()
/usr/local/go/src/runtime/proc.go:203 +0x21e fp=0xc00016dfe0 sp=0xc00016df60 pc=0x434f7e
runtime.goexit()
/usr/local/go/src/runtime/asm_amd64.s:1357 +0x1 fp=0xc00016dfe8 sp=0xc00016dfe0 pc=0x463541
goroutine 13 [select]:
database/sql.(*DB).connectionOpener(0xc0001b03c0, 0x104a820, 0xc000191800)
/usr/local/go/src/database/sql/sql.go:1052 +0xe8
/usr/local/go/src/database/sql/sql.go:722 +0x15d
goroutine 12 [chan receive]:
storj.io/storj/pkg/process.Ctx.func1(0xc0002b75c0, 0xc000314f60)
/go/src/storj.io/storj/pkg/process/exec_conf.go:89 +0x41
created by storj.io/storj/pkg/process.Ctx
/go/src/storj.io/storj/pkg/process/exec_conf.go:88 +0x1b6
goroutine 10 [IO wait]:
internal/poll.runtime_pollWait(0x7f0e59e4dea8, 0x72, 0x0)
/usr/local/go/src/runtime/netpoll.go:184 +0x55
internal/poll.(*pollDesc).wait(0xc000117498, 0x72, 0x0, 0x0, 0xef9734)
/usr/local/go/src/internal/poll/fd_poll_runtime.go:87 +0x45
internal/poll.(*pollDesc).waitRead(…)
/usr/local/go/src/internal/poll/fd_poll_runtime.go:92
internal/poll.(*FD).Accept(0xc000117480, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0)
/usr/local/go/src/internal/poll/fd_unix.go:384 +0x1f8
net.(*netFD).accept(0xc000117480, 0xc000060cc0, 0xc000184000, 0x7f0e5c18a6d0)
/usr/local/go/src/net/fd_unix.go:238 +0x42
net.(*TCPListener).accept(0xc00028f7e0, 0xc000060cf0, 0x4110a8, 0x30)
/usr/local/go/src/net/tcpsock_posix.go:139 +0x32
net.(*TCPListener).Accept(0xc00028f7e0, 0xe60d20, 0xc00017e1e0, 0xdb22e0, 0x187c0a0)
/usr/local/go/src/net/tcpsock.go:261 +0x47
net/http.(*Server).Serve(0xc00032e000, 0x1044fa0, 0xc00028f7e0, 0x0, 0x0)
/usr/local/go/src/net/http/server.go:2896 +0x286
storj.io/storj/pkg/process.initDebug.func2(0xc0002b7380, 0x1044fa0, 0xc00028f7e0, 0xc000191400)
/go/src/storj.io/storj/pkg/process/debug.go:52 +0x15d
created by storj.io/storj/pkg/process.initDebug
/go/src/storj.io/storj/pkg/process/debug.go:50 +0x38f
goroutine 21 [syscall]:
os/signal.signal_recv(0x0)
/usr/local/go/src/runtime/sigqueue.go:147 +0x9c
os/signal.loop()
/usr/local/go/src/os/signal/signal_unix.go:23 +0x22
created by os/signal.init.0
/usr/local/go/src/os/signal/signal_unix.go:29 +0x41
database/sql.(*DB).connectionResetter(0xc0001b03c0, 0x104a820, 0xc000191800)
fmas@delta:~$
