Where are you hosting this node if I may ask?
@saamxvr which Docker version is your node running?
You can check it with docker version.
I’d suggest you to update your Docker to the version 19.03.
its all upto date … its fresh installation …
That’s odd =/
So please paste the output of these 2 commands:
docker info
And
uname -a
can we scale to admin team ? i can provide dedicated server information to look in to it …
You really shouldn’t use RAID0.
Problem got solved … its OS not support with dockker … i use Debian now … and work fine !
