Hello , i have install storj on Linux untill last comment it was sucssefully installed when i hit this command on command port
-p 28967:28967
-p 127.0.0.1:14002:14002
-e WALLET=“0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX”
-e EMAIL="user@example.com "
-e ADDRESS=“domain.ddns.net:28967 ”
-e STORAGE=“2TB”
–mount type=bind,source=“”,destination=/app/identity
–mount type=bind,source=“”,destination=/app/config
I getting
unknown flag: --mount
See ‘docker run --help’.
Any idea ?
my real mount path is
–mount type=bind,source=“/root/.local/share/storj/identity/storagenode”,destination=/app/identity
–mount type=bind,source=“/storjfile”,destination=/app/config \
Here is my RAID0 Patation look like
[root@53535 ~]# df
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 8114588 0 8114588 0% /dev
tmpfs 8126380 0 8126380 0% /dev/shm
tmpfs 8126380 9012 8117368 1% /run
tmpfs 8126380 0 8126380 0% /sys/fs/cgroup
/dev/sda3 3843262592 1670172 3646341784 1% /
/dev/sda2 194235 121295 58604 68% /boot
tmpfs 1625276 0 1625276 0% /run/user/0
ufo56
March 27, 2020, 12:31pm
2
-p 28967:28967 \
-p 127.0.0.1:14002:14002 \
-e WALLET="0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" \
-e EMAIL="user@example.com" \
-e ADDRESS="domain.ddns.net:28967" \
-e STORAGE="2TB" \
--mount type=bind,source="<identity-dir>",destination=/app/identity \
--mount type=bind,source="<storage-dir>",destination=/app/config \
--name storagenode storjlabs/storagenode:beta
Your docker run command line is missing backslashes at line endings
VIDEO
take look tutorial there no black slash at end of line
ufo56
March 27, 2020, 12:56pm
4
Yes i mean i copy from source page and past in to text editor so there is blackslash at the end
here is my orginal code look like
> -p 28967:28967 \
> -e WALLET="removed" \
> -e EMAIL="removed" \
> -e ADDRESS="removed:28967" \
> -e STORAGE="3.6TB" \
> --mount type=bind,source="/root/.local/share/storj/identity/storagenode",destination=/app/identity \
> --mount type=bind,source="/mnt/storjfiles",destination=/app/config \
I fallow this static Mount too
https://documentation.storj.io/resources/faq/linux-static-mount
I tired to use -v instead of --mount here is output look like
/usr/bin/docker-current: Error response from daemon: invalid volume spec "type=b ind,source=/mnt/storjfiles,destination=/app/config": invalid volume specificatio n: 'type=bind,source=/mnt/storjfiles,destination=/app/config': invalid mount con fig for type "volume": invalid mount path: 'type=bind,source=/mnt/storjfiles,des tination=/app/config' mount path must be absolute.
See '/usr/bin/docker-current run --help'.
Here is my mount disk path
sda3 ext4 f77fd259-213d-40b3-b874-91b81cae0af7 /mnt/storjfiles
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 3.7T 0 disk
├─sda1 8:1 0 1M 0 part
├─sda2 8:2 0 200M 0 part /boot
├─sda3 8:3 0 3.7T 0 part /mnt/storjfiles
└─sda4 8:4 0 1G 0 part [SWAP]
DO NOT USE -v and follow the documentation.
I would recommend setting your storage to 3.5TB to be safe. You need to keep 10% as overhead to avoid your node getting in trouble of over-allocation.
Can you show the screen where you enter the command?
i use putty … do you want screen shot ?
Here here output of docker ruining test
[root@PAR-193655 ~]# docker ps -a
fe89f964eead hello-world "/hello" About an hour ago Exited (0) About an hour ago sharp_agnesi
5bf42af4d59d hello-world "/hello" 4 hours ago Exited (0) 4 hours ago festive_pasteur
Try entering the command in 1 single line without using the enter key. You can copy it from documentation and edit the fields with your info.
I didn’t get you , could you please describe or give me some example ? i use NOTE ++ so hope it wont have any empty space
https://documentation.storj.io/setup/cli/storage-node#running-the-storage-node
Check the template of the command. It has no new line for Windows. I don’t think its an issue but I wanted to rule that out.
Yes i copy from it in to NOTE ++ so no empty line now it have 10 lines same as doc
Could you show the notepad++ screen?
Could it be that the version you are running still requires the bandwidth parameter?
Try adding ‘-e BANDWIDTH="30TB" \’ before the ‘STORAGE=’ parameter.
Remove all the \ and get all the parameters in 1 single line instead of 10 lines. Copy + paste that on your putty screen.
Like this
docker run -d --restart unless-stopped --stop-timeout 300 -p 28967:28967 -p 127.0.0.1:14002:14002 -e WALLET=“0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX” -e EMAIL="user@example.com " -e ADDRESS=“domain.ddns.net:28967 ” -e STORAGE=“2TB” --mount type=bind,source=“”,destination=/app/identity --mount type=bind,source=“”,destination=/app/config --name storagenode storjlabs/storagenode:beta
jammerdan:
-e BANDWIDTH="30TB
Yes i did it … same error
I did try … same error
