Again, update my node to 1.3.3 and goes offline, whats happens
Alexey
April 25, 2020, 2:52pm
2
Please, post the last 20 lines of your log .
Press Ctrl-F5 on your dashboard
tnks, but i reinstaled 5 times and in 6° time worked
Alexey
April 25, 2020, 5:28pm
4
Looks like a problem either with a firewall, or with port forwarding.
Can you check this?
It should connect in seconds. There are a few things you should check.
Start with checking the port. On https://www.yougetsignal.com/tools/open-ports/?port=28967 you can fill in the domain or IP you are using in the run command. Then check the port.
If it’s closed, it could still be several things.
Make sure the WAN IP you see in your router settings matches the IP shown on the above page.
Make sure your port forward is set up correctly. That means no filter on incoming IPs, forwarding to th…
normally doing the exactly same activity 6 times would not guarantee any better success than the first time. I think it would be good if you could send some logs to storj if this is a bug.
