When we did the payouts for the held amount on satellite.stefan-benten.de 100 percent of all held amount was paid back. When you are looking at your node dashboard I believe you need to use the date filter to look 1 month in the future because technically these payouts for the held amount on that satellite would have gone out in October.
Now you made me open the heldamount.db and look around ![]()
There is no disposed amount mentioned for this satellite at all (other than the normal one in month 16), so the dashboard can’t display it anywhere (yet).
so any information about the repurposing of Stefan’s satellite except the announcement that it will be shut down?
i missed this, and i think it’s not good that payout data like this isn’t atleast stored locally so that even after a satellite is gone i can check the numbers i have…
i can see that i have substantial payouts in relation to the missing satellite because the variation between the payments and the actual dashboard numbers show a 50% deviation i think it was… tho i have no way of verifying if i ever got my heldback amount…
i’m sure i did, i’m sure most people did, if not all…
just saying this isn’t a good way to do business…
yes granted there is an argument to be made for that i should have logged the information myself… but i didn’t… and i don’t think i should need to… in 99% of all cases…
My nodes still shows the payout information from the satellite
i do manual updates which involves doing a docker rm storagenode
can’t think of anything else that might cause it…
The information is stored in the local database. If they are got removed with the container, you setup it wrong.
i may have migrated the node 2 or 3 months back… maybe thats what did it… it does seem to be around that time… but everything is default and i moved the storagenode as recommended in the documentation…
i duno… maybe i did something wrong… i totally forgot about migrating it
