Congratz, you saturated my connection. ![]()
Edit: CPU for context.
It’s busy, but acceptable.
How does your upload successrate looks with circuit being saturated?
Better than the last tests during the night. Succeeding most transfers. I don’t have exact numbers though.
The last test run was bestofn with n=3. This time we uploaded to all nodes and not just vetted nodes. We hit our goal for the first time.
Now trying n=3.5 and later n=2.5. Also on the list is to make the long tail a bit shorter like 3-5 extra nodes instead of the current 8.
What I don’t understand is why the unvetted nodes have such an impact. The fact that you get higher load on your node means this is more a side effect. That is something I will question later.
Nice to hear that! Can you tell us more precisely what the goal is? How much bandwidth is the target?
At least in my case I have nodes that are almost 6 months old and still have not received a single audit from saltlate in any of them.
My guess is that this might be the situation for a lot of others nodes, and if so, there is a significant amount of nodes (and therefore bandwidth) that has not been used in previous tests.
I don’t have any unvetted nodes though. I can only speculate that currently my SSD cache isn’t saturated, which it was during the last tests during the night.
Aaaaah! I did wonder what had happened when my non-vetted nodes went a bit crazy ![]()
You beat me to it.
I have about 5 nodes of different ages (all between 3 and 6 months old) and none of them have received a single audit from Salt Lake either.
I think vetting is broken on that sattelite…
Why are there such a sharp fall off cliffs? Was this the actual expected load pattern or was there some bottleneck getting overwhelmed?
Most likely the test was stopped so the traffic went down immediately.
Fresh information from our standup:
With my internet connection at the limit I guess it only depends on average TTL how much storage I can accumulate… ![]()
Any ideas how to reject uploads based on TTL? ![]()
Just do the math. For my node I came to the conclusion that I just need a faster internet connection and my storage node payout is going to cover the extra costs.
Currently testing choiceofn with n=4
It should be less biased and less risky than bestofn. I really hope we can get to the same throughput with this one. It would be my favorit.
Nothing faster available here. Thus the question about TTL.
