Uplink-nodejs - how to create a sharable URL for an object in a bucket?
I can create shareable links to objects using the WEB interface, but how can it be done programmatically in nodejs?
Here, I can see that a shared URL has a structure like:
https://link.us1.storjshare.io/” + accessKey+ “/” + bucket_name + “/” + object_name
But I can’t find what this accessKey is and how I can retrive it from an “access”. In the links that I create in the web interface, this accessKey has 28 characters.
Basically, what I need is a link to the object that can be used in NFT metadata.
Have your read this ? :point_down:
You need to generate an access grant and register it on auth service to get an S3 credentials with public access.
With CLI it is an equivalent of the command:
uplink share --url --not-after=+1h sj://my-bucket/my-prefix/my-object.txt
Or
uplink share --register --public --not-after +1h --readonly sj://my-bucket/my-prefix/my-object.txt
As result you will get an access grant, S3 credentials and linkshare URL. Where Access Key is a key what you need to form this URL.
Please note --public option, without it these S3 credentials will not register an Access Key as public.
So, you need a share and register functions in uplink-nodejs.
Share: Document
Unfortunately, I didn’t find an analogue for storj/cmd_access_register.go at ea1408f7a842c0314f7a0064bfa325fb7faf3a6e · storj/storj · GitHub
Yes. I looked at the docs, but they only refer to CLI and I need to do this programmatically.
Obviously, I can always execute a shell command programmatically, but this is often not reliable and I would prefer to do it via code.
Access part, I know how to do it. There is also an example in HelloStorj.
Unfortunatelly, the “register” part does no seem to be available in uplink-nodejs.
I would like to wait for developers (they are available on workdays) to confirm that.
If C# and .Net are an Option for you, you may take a look at uplink.net - it includes the register-functionality.
Not an option for me. But if a solution exist using python3, then I can use that as a temporary solution. The core development is in nodejs.
I concur with @Alexey- it looks like there is no code in uplink-nodejs to perform the RegisterAccess api. It also looks like there is no code for that in uplink-python, either.
I don’t think there is any fundamental reason why either library couldn’t provide that functionality.
I’ve gotten the topic onto a meeting agenda at Storj, so hopefully we’ll be able to get that work on the roadmap at least.
Thank you for the respose. For a PoC, I will try to get something running using one of the languages that support this feature.
Is this roadmap public?
I don’t believe we have any official public roadmap information right now, but we should be able to give you some idea of how it’s prioritized and/or scheduled.
I think shelling out to the uplink CLI might be the best thing for now.
