Uplink: stream: context canceled
Hello,
I’m trying to upload some files using uplink.
A simple 10GB file took 5 retries to upload, it fails at random with a bunch of:
stream: context canceled; ecclient: upload cancelled by user
It amazes me that this application doesn’t have a simple retry function.
Further on, it seems that the bandwidth used to upload, sometimes 90%, of the file still accountable.
Is there anything I can do to fix this issue?
Thanks
did you used parallelism?
if yes how much?
I tried with (-p 16) and without (defaults to 1), same results.
Additionally, I’m uploading a single large file.
I tried 5 gb file, and it work paralelism 10 Maxed my 500 Mbit connection
what connection do you have?
Can you post a screenshot of the full error output?
I got 300mbit up, here’s a log of my last attempt
./uplink cp /path/to/file.gpg sj://test-bucket -p 16 -t 16
upload /path/to/file.gpg to sj://test-bucket/file.gpg
288.41 MiB / 44.70 GiB [->______________________________________________________________________________________________________________________________________________________________________________________________________________________2.88 GiB / 44.70 GiB [-->__________________________________] 6.43% 10.40 MiB p/s
failed to upload part 28: uplink: stream: ecclient: successful puts (69) less than success threshold (80), ecclient: upload failed (node:1s4QQsF8VkyTefmsj668haWjZ5yhEqyNkcSvrYFUaKqGqs5qwx, address:45.45.216.242:28967): rpc: tcp connector failed: rpc: dial tcp 45.45.216.242:28967: connect: connection timed out; ecclient: upload failed (node:123Zycv7LFzPacpJ9Zbj3PxeWQkEeVq2ioiA7XtHPwWz2sz2oyB, address:54.36.72.175:28967): rpc: tcp connector failed: rpc: dial tcp 54.36.72.175:28967: connect: connection timed out; ecclient: upload failed (node:1aaGALg3vwEW7tJYTDRprNtziH3pZRrMvbVAf4rqQMP4b72VqK, address:87.218.134.131:28967): rpc: tcp connector failed: rpc: dial tcp 87.218.134.131:28967: connect: connection timed out; ecclient: upload failed (node:12EWKzHj4ZL876RXcbscM7XYidU63FmJ2LaFa35zvDCtyHvqGn5, address:185.246.211.182:44460): rpc: tcp connector failed: rpc: dial tcp 185.246.211.182:44460: connect: connection timed out; ecclient: upload failed (node:1XnPNEZ7svKaSNdTsyPY7EY8EKELacEpqTyJLUHiQmagbv9b2Y, address:93.89.251.235:28967): rpc: tcp connector failed: rpc: dial tcp 93.89.251.235:28967: connect: connection timed out; ecclient: upload failed (node:14nRPpAvwF9h2a8o7Zoa6jk2SHWu7dPRfv17WnfzFHmAjze4Tk, address:164.132.84.5:28967): rpc: tcp connector failed: rpc: dial tcp 164.132.84.5:28967: connect: connection timed out; ecclient: upload failed (node:12gmK53ntPqZyhH5uP5EokmBquzqt8ZUuDu6Bodkx4VPQGv5eq6, address:71.8.14.48:28967): rpc: tcp connector failed: rpc: dial tcp 71.8.14.48:28967: connect: connection timed out; ecclient: upload failed (node:122pHGwGTfugcLuePu5P3T3Tiwhv8o1a1TSpewasnUfzEawyXNY, address:92.189.193.60:28967): rpc: tcp connector failed: rpc: dial tcp 92.189.193.60:28967: connect: connection timed out; ecclient: upload failed (node:1yNtdKsoPwAobkE6X7fCjYBnPaTwFw65Trv68btBcZqwAsbA1q, address:51.195.195.198:28967): rpc: tcp connector failed: rpc: dial tcp 51.195.195.198:28967: connect: connection timed out; ecclient: upload failed (node:1LT6VcG3fJVnP2RHHtUHEjkk6D3FGXKPLnHRedP2sWKFu7Huty, address:72.208.244.30:28967): rpc: tcp connector failed: rpc: dial tcp 72.208.244.30:28967: connect: connection timed out; ecclient: upload failed (node:1rg3vcxsmQXypi6zQnVD2oSrRvQ5fYj27SLhXRX1MxJGJ57Euq, address:73.43.63.133:28967): rpc: tcp connector failed: rpc: dial tcp 73.43.63.133:28967: connect: connection timed out; ecclient: upload failed (node:12YY1wrv8dVH4QVhDNLFRkemoGb5EBJA3BYpb4jc1LuM3eyXfhs, address:79.114.97.85:28967): rpc: tcp connector failed: rpc: dial tcp 79.114.97.85:28967: connect: connection timed out; ecclient: upload failed (node:125TELbmBMmEt9BoBfqtek7ZutEBHsDeXmLSjZUdUk87wSF17By, address:85.148.16.77:28966): rpc: tcp connector failed: rpc: dial tcp 85.148.16.77:28966: connect: connection timed out; ecclient: upload failed (node:12EbkVXtqjB96EvfRE5gv9xVx7niFmtkWnNLMDfBA1u2S1qcT7r, address:130.185.85.106:61595): rpc: tcp connector failed: rpc: dial tcp 130.185.85.106:61595: connect: connection timed out; ecclient: upload failed (node:1yvtdrXJfu5UNi7iS7bTxzVP5h7q8n3og3oQU7ahzLkEyA6Rgf, address:213.32.11.149:28967): rpc: tcp connector failed: rpc: dial tcp 213.32.11.149:28967: connect: connection timed out; ecclient: upload failed (node:1PUJUVPtiadGn6CJyTPdzGPJ4Qv6GaLhK9TdJKTpyy3beXQyBY, address:211.195.60.136:28967): rpc: tcp connector failed: rpc: dial tcp 211.195.60.136:28967: connect: connection timed out; ecclient: upload failed (node:1SU6B51iwDz6qBsXzXPWa8B5EJU6iooZtshoRuWwuokqX1Rhcn, address:84.68.159.187:28969): rpc: tcp connector failed: rpc: dial tcp 84.68.159.187:28969: connect: connection timed out; ecclient: upload failed (node:1MyJVuWf3QFVXEyQCLuvuoXahkbzvR8kVYgDfWqtEHArAANgMw, address:174.96.234.89:28968): rpc: tcp connector failed: rpc: dial tcp 174.96.234.89:28968: connect: connection timed out; ecclient: upload failed (node:1LfH9ZZJj5YhQhqKSGTS9NpU784TwLPWfucdCTEvbHNX74i9ys, address:185.189.13.233:23005): rpc: tcp connector failed: rpc: dial tcp 185.189.13.233:23005: connect: connection timed out; ecclient: upload failed (node:12V5RurnpPSskFo2K4n87eQEKDjG3WNj2hdmB256gJE4pabJPiB, address:78.46.134.148:28967): rpc: tcp connector failed: rpc: dial tcp 78.46.134.148:28967: connect: connection timed out; ecclient: upload failed (node:1298Za4YWHYy6h4VpJrqyxuGbBucx8CW2wDNHV5sfSRy4qMD1Gs, address:51.195.166.5:28967): rpc: tcp connector failed: rpc: dial tcp 51.195.166.5:28967: connect: connection timed out; ecclient: upload failed (node:12CU87RgUTfvnXwRUSdJoEdH5PdFZrDXn3HGvo6QfN1YMGUrmGM, address:193.142.58.194:28967): rpc: tcp connector failed: rpc: dial tcp 193.142.58.194:28967: connect: connection timed out; ecclient: upload failed (node:12ECM51ci2CoBQ8xJv3aswdXLzp2GncDHjsZhQSepiEqBUWbnD8, address:147.219.137.140:28967): rpc: tcp connector failed: rpc: dial tcp 147.219.137.140:28967: connect: connection timed out; ecclient: upload failed (node:1gNaqW1uhbz2574LSXbFJKqG5L2oB66iQHkxGkGkq3QgXpuy4M, address:211.226.92.169:28967): rpc: tcp connector failed: rpc: dial tcp 211.226.92.169:28967: connect: connection timed out; ecclient: upload failed (node:1JSJGJgHgL178EHxqdBCBPVfzgZxn7KLtDfTAk1LBJT6zbrYg7, address:78.99.200.242:30005): rpc: tcp connector failed: rpc: dial tcp 78.99.200.242:30005: connect: connection timed out; ecclient: upload failed (node:12dq42ZUZCKZY8X2KQViepqqayHwa6neSNfnUex8EJTxfFKTiVZ, address:139.99.114.130:28996): rpc: tcp connector failed: rpc: dial tcp 139.99.114.130:28996: connect: connection timed out; ecclient: upload failed (node:12VRVKNkHnVwP3EsLiQhF6QQLScxENkhLoRSekyhqi3Pyd8iXge, address:5.9.41.207:28967): rpc: tcp connector failed: rpc: dial tcp 5.9.41.207:28967: connect: connection timed out; ecclient: upload failed (node:12qqTSH89pNpDEE2xeqWeRRxJW1mW7GZtQSRMjFzK4NdZNnjB6t, address:108.4.152.30:30001): rpc: tcp connector failed: rpc: dial tcp 108.4.152.30:30001: connect: connection timed out; ecclient: upload failed (node:1a3fikgqeP3H13HpToAV4SfntzAphZakvkTUqt4FExGNQ8z1KA, address:178.170.55.55:28967): rpc: tcp connector failed: rpc: dial tcp 178.170.55.55:28967: connect: connection timed out; ecclient: upload failed (node:1LYun83PAsvPvYuWKvJ8bSJoo9cPoHNZRdhweM1wtmjsYwszcu, address:65.21.226.148:32757): rpc: tcp connector failed: rpc: dial tcp 65.21.226.148:32757: connect: connection timed out; ecclient: upload failed (node:12qqceupyntT3vxhd5uepTkJ3X8iDXMNHeeLJaEmeYgF8U3WQQ5, address:82.223.108.33:10026): rpc: tcp connector failed: rpc: dial tcp 82.223.108.33:10026: connect: connection timed out; ecclient: upload failed (node:1oZSiabTFTtBHDX3GoSLC3ytmg8hDPLtxD7upe11i92ohnRYQf, address:136.37.110.58:28967): rpc: tcp connector failed: rpc: dial tcp 136.37.110.58:28967: connect: connection timed out; ecclient: upload failed (node:12WhPUPvVy6y6TUj9PstBsdjdbGaRYjkYxXHVtN96xeY3tsVfJm, address:91.134.158.27:30068): rpc: tcp connector failed: rpc: dial tcp 91.134.158.27:30068: connect: connection timed out; ecclient: upload failed (node:12iY6FTEQPQsyJnxnbkgyMZojmPSH3FJiuCYcZrywYTAb5uZKBB, address:188.225.42.170:28967): rpc: tcp connector failed: rpc: dial tcp 188.225.42.170:28967: connect: connection timed out; ecclient: upload failed (node:19StgMkEikatCutKgSsKjwzn3gbpLKYDgwhCd7mufUmEGCKTHW, address:178.124.222.42:28967): rpc: tcp connector failed: rpc: dial tcp 178.124.222.42:28967: connect: connection timed out; ecclient: upload failed (node:12ZVWxeomCkgn4QpBtS3CxYxPdPbqK6XFazo1WvobE1zn6t6wpH, address:1.214.252.226:28967): rpc: tcp connector failed: rpc: dial tcp 1.214.252.226:28967: connect: connection timed out; ecclient: upload failed (node:12po1DXuj3UNGk8h6YX6ZS4PNLPLH3mBnwaAv96odPwhEgY6DDF, address:93.176.171.236:28969): rpc: tcp connector failed: rpc: dial tcp 93.176.171.236:28969: connect: connection timed out; ecclient: upload failed (node:1rCk95biinWx2g9z9H6RSjof1ww4F5zuFVGZTdfaKQ4Btyzdub, address:89.223.71.17:28967): rpc: tcp connector failed: rpc: dial tcp 89.223.71.17:28967: connect: connection timed out; ecclient: upload failed (node:128YvRHFuYLrAT9Tw61kBYXG78ZhLgYhyWXU7XL1EpzDFc2ZStD, address:188.225.75.242:28967): rpc: tcp connector failed: rpc: dial tcp 188.225.75.242:28967: connect: connection timed out; ecclient: upload failed (node:1pC7Xjpv64GBBKZwtNjZXBurS2B9drEttxCC8ii7wfE1o7X5T7, address:88.99.163.55:28967): rpc: tcp connector failed: rpc: dial tcp 88.99.163.55:28967: connect: connection timed out; ecclient: upload failed (node:1DPaRvJEF12PdDw9EzW4wU6XSj9WnjfRi6Rb1Lejjs7FdPDnAu, address:37.110.200.51:28967): rpc: tcp connector failed: rpc: dial tcp 37.110.200.51:28967: connect: connection timed out
failed to upload part 43: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 40: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 36: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 39: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 35: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 26: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 45: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 41: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 34: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 42: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 38: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 37: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 32: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 33: uplink: stream: context canceled; ecclient: upload cancelled by user
failed to upload part 44: uplink: stream: context canceled; ecclient: upload cancelled by user
Could you try the following?
./uplink cp /path/to/file.gpg sj://test-bucket -p 2
Also I would try restarting your router as well
Hello,
As I said earlier, I tried with the defaults too. -p 2 gives the same result. It went a little further this time, but this is random, I had it failing at 1mb before:
29.25 GiB / 44.70 GiB [----------------------->____________] 65.44% 8.67 MiB p/s
failed to upload part 461: uplink: stream: ecclient: successful puts (67) less than success threshold (80), ecclient: upload failed (node:12SSVXLepggoPKjrn1BdxNgbun3LBhsdGaFBmCg2mfcDuS1z26s, address:178.32.68.184:10189): protocol: storage node overloaded, request limit: 10; ecclient: upload failed (node:1JtFKarLcfqUtedJaoPuiH9fyYWArGjPNoWa2i82ngNyFUh7aL, address:98.10.173.16:28967): rpc: tcp connector failed: rpc: dial tcp 98.10.173.16:28967: connect: connection timed out; ecclient: upload failed (node:1GUDNJT4T9w5Uo7X8UPQpeedwrxmw5v4Tt9Jicbdjk5AV9tCwW, address:91.201.233.108:28967): rpc: tcp connector failed: rpc: dial tcp 91.201.233.108:28967: connect: connection timed out; ecclient: upload failed (node:1sd6ZrCqYDN5LZqV1mUWQYAsU2geurNDau1chtwi68BzcvBk99, address:77.81.139.58:28967): rpc: tcp connector failed: rpc: dial tcp 77.81.139.58:28967: connect: connection timed out; ecclient: upload failed (node:1NTkPLxNm8DKT8tgXt4VZaMwrPgSdr5EVZgvtRz6sZHYzsmrCt, address:62.217.187.158:28980): rpc: tcp connector failed: rpc: dial tcp 62.217.187.158:28980: connect: connection timed out; ecclient: upload failed (node:12rGthJNtrFUVAbTeqZZCPqtcdfkWKQ1srMX8LSbLsw66w585Rt, address:93.245.169.139:28006): rpc: tcp connector failed: rpc: dial tcp 93.245.169.139:28006: connect: connection timed out; ecclient: upload failed (node:12axztwi4daDss2VDk8zh8wSouv8r1jot2dmhv5jJMKNqE9e2tX, address:83.217.4.41:24020): rpc: tcp connector failed: rpc: dial tcp 83.217.4.41:24020: connect: connection timed out; ecclient: upload failed (node:1BFa4rqbEkB7BugNPMg8SyH4MtofuP27ymoJMwkiMVJLpmVvnT, address:188.126.89.51:39189): rpc: tcp connector failed: rpc: dial tcp 188.126.89.51:39189: connect: connection timed out; ecclient: upload failed (node:121Hq42g3EBCoiaL1oB5kwzVdG5G2n1gbRTcHFbMMTTP9g9ZDLc, address:141.147.31.167:8080): rpc: tcp connector failed: rpc: dial tcp 141.147.31.167:8080: connect: connection timed out; ecclient: upload failed (node:12ZbQj7RmRPFFCAU9DY9YPLZDeyzV1A4E9CsGKHMb5YzCicMv3u, address:51.195.247.14:28967): rpc: tcp connector failed: rpc: dial tcp 51.195.247.14:28967: connect: connection timed out; ecclient: upload failed (node:12n4oHkdWLZwJUpmXqYCtAqArXUaDYawbKStNuBibMVvrNgaqU1, address:82.66.46.25:28967): rpc: tcp connector failed: rpc: dial tcp 82.66.46.25:28967: connect: connection timed out; ecclient: upload failed (node:12GfP3TYZUKfn3Bs74S5EkwBVJJ3EkCzGSEyHGfCFsPogFTTxi9, address:58.71.144.29:20988): rpc: tcp connector failed: rpc: dial tcp 58.71.144.29:20988: connect: connection timed out; ecclient: upload failed (node:12T1ngwmbqiWk2cBPNLXp5cakZAVkTtydSQGtjmM23uiq2TSHxg, address:62.76.90.7:28967): rpc: tcp connector failed: rpc: dial tcp 62.76.90.7:28967: connect: connection timed out; ecclient: upload failed (node:12GW8m2y2iv97hijXdnbUPgBU3o4LVSp6RG7Z6czBYQMoRTfX1k, address:91.219.60.40:28967): rpc: tcp connector failed: rpc: dial tcp 91.219.60.40:28967: connect: connection timed out; ecclient: upload failed (node:12rnuSPegjGZ4yMCyVNmkWTDr4KxutBD4k2MWSJRLp5t8wXaE5c, address:88.198.196.187:28027): rpc: tcp connector failed: rpc: dial tcp 88.198.196.187:28027: connect: connection timed out; ecclient: upload failed (node:1nWgJLQUU4dQviQtyzuVA3aX4bJj97h5GjC1TVf5KYW4LYjdb8, address:92.39.99.2:28967): rpc: tcp connector failed: rpc: dial tcp 92.39.99.2:28967: connect: connection timed out; ecclient: upload failed (node:1ixSW3hQrGr9zcDowajrtcFJCuBEKQbkTNyhmyByRVDUZ9Kqgx, address:81.30.158.196:28973): rpc: tcp connector failed: rpc: dial tcp 81.30.158.196:28973: connect: connection timed out; ecclient: upload failed (node:16NP61VDQVD4KCjFbPsSMjcuSeTzFdasiLyUCwdiat1B6CfH1e, address:51.91.178.84:42000): rpc: tcp connector failed: rpc: dial tcp 51.91.178.84:42000: connect: connection timed out; ecclient: upload failed (node:1LKjSRMkZVjwivX4QjJkv8pryBJpxKY9qeZtU9qLkQcxHyo4JN, address:146.59.89.155:28907): rpc: tcp connector failed: rpc: dial tcp 146.59.89.155:28907: connect: connection timed out; ecclient: upload failed (node:1SyNKYNhXQAbVuyMjszkKP5wowrFW1MHeapXw6vnstaV1f4kPM, address:194.230.127.187:28967): rpc: tcp connector failed: rpc: dial tcp 194.230.127.187:28967: connect: connection timed out; ecclient: upload failed (node:12faSt6CUtm6fAm2Lqh8aSK1Y9RHaybeYXXmvwweHQSUTEq5WsU, address:140.238.93.148:28967): rpc: tcp connector failed: rpc: dial tcp 140.238.93.148:28967: connect: connection timed out; ecclient: upload failed (node:15yRFrnQDQ35tD4brFq4UDpp9ssEpsVHHVN4UeBAfVJ3xP4AVq, address:79.159.33.177:28968): rpc: tcp connector failed: rpc: dial tcp 79.159.33.177:28968: connect: connection timed out; ecclient: upload failed (node:121Ljgc8LJyByV3AYZaLTC7y2JRMNyVrd9owEa8dZmje29MPxHh, address:84.39.117.57:51114): rpc: tcp connector failed: rpc: dial tcp 84.39.117.57:51114: connect: connection timed out; ecclient: upload failed (node:1294KPhRSHUAwRE7R5oyLqWyCrGN56ZqWPedeinZugKoyNLhXUx, address:164.152.166.237:28967): rpc: tcp connector failed: rpc: dial tcp 164.152.166.237:28967: connect: connection timed out; ecclient: upload failed (node:18YMCUN22HvWUQxag9smdiRWeSJ6LgqCfx6hgPK3Q5hrhUprK6, address:195.2.85.159:30017): rpc: tcp connector failed: rpc: dial tcp 195.2.85.159:30017: connect: connection timed out; ecclient: upload failed (node:1cbsmKVvGVjjZr4AVndjrbVqYLiszJBMabpoJ82GjVP6T8xiGA, address:82.165.168.234:28992): rpc: tcp connector failed: rpc: dial tcp 82.165.168.234:28992: connect: connection timed out; ecclient: upload failed (node:1cJCy23Gmqa3dAtrb1mxiKfN16u3RDgdGXmnTmVXTAqRxUkKNP, address:54.38.197.122:37401): rpc: tcp connector failed: rpc: dial tcp 54.38.197.122:37401: connect: connection timed out; ecclient: upload failed (node:19ax6DJafeS93JWmt9RFT4eNbqVtk673EgnhmmTudPjKnHQ5hL, address:109.107.177.206:30242): rpc: tcp connector failed: rpc: dial tcp 109.107.177.206:30242: connect: connection timed out; ecclient: upload failed (node:12jW15vZvYJcypE3fiWigpFaZq2r23WiwMqc7ERi1PNPgWeNSkf, address:65.108.249.226:28904): rpc: tcp connector failed: rpc: dial tcp 65.108.249.226:28904: connect: connection timed out; ecclient: upload failed (node:12UfXqwwyyFTez3yRWDNBfemY9bfCpYPGQDw4FVvdzPpT9rLC94, address:90.116.186.197:28968): rpc: tcp connector failed: rpc: dial tcp 90.116.186.197:28968: connect: connection timed out; ecclient: upload failed (node:12er9VGrhCcYu1oqBnDaX5Ydp6XodrD2YEwN5ky8MaN5GnySU8w, address:164.132.176.50:3082): rpc: tcp connector failed: rpc: dial tcp 164.132.176.50:3082: connect: connection timed out; ecclient: upload failed (node:15MHUqgz2yUaXNX32FWu5ahxeadSqcGjr1M8SKjkQ3cvnHvyP3, address:5.28.168.130:20988): rpc: tcp connector failed: rpc: dial tcp 5.28.168.130:20988: connect: connection timed out; ecclient: upload failed (node:1oP5FGKvzqXiuQtjAWGGSiJgoJQy2oPCNQZZ72KCHWGzip9S4X, address:47.62.118.253:28968): rpc: tcp connector failed: rpc: dial tcp 47.62.118.253:28968: connect: connection timed out; ecclient: upload failed (node:1evzScFpF2q4DaH5Lzif54BuK9sPU5yRYr1QtxNojthetXiU1F, address:94.127.32.164:28967): rpc: tcp connector failed: rpc: dial tcp 94.127.32.164:28967: connect: connection timed out; ecclient: upload failed (node:12Px6nbvaM9LrkD6XquKMjnm4NXvXkYBfjHxkxGPvToyjRByHN7, address:202.43.233.135:28967): rpc: tcp connector failed: rpc: dial tcp 202.43.233.135:28967: connect: connection timed out; ecclient: upload failed (node:12a3M5K32Fotnq79GJhEyFGLp8CYvg1vypJvpoqRQV9oHi4v3YF, address:88.17.196.110:10101): rpc: tcp connector failed: rpc: dial tcp 88.17.196.110:10101: connect: connection timed out; ecclient: upload failed (node:12JkfeaXFreyyRc8x4DiTyEeTZDH2sUw3LCQhW27Y8JncN875cG, address:141.144.197.147:28972): rpc: tcp connector failed: rpc: dial tcp 141.144.197.147:28972: connect: connection timed out; ecclient: upload failed (node:1XkEcv8KUmqNGbxntVdjkdTV9fHFdRbNKPqRpygbu5JQG1vvFc, address:145.239.118.167:29034): rpc: tcp connector failed: rpc: dial tcp 145.239.118.167:29034: connect: connection timed out; ecclient: upload failed (node:12QLjdookoC9AzWuNiatFfuFS67A4gcZkwXDbVqpH5gxV1sjnby, address:51.161.130.88:28968): rpc: tcp connector failed: rpc: dial tcp 51.161.130.88:28968: connect: connection timed out; ecclient: upload failed (node:12HEQ8BGqmHG8et34kK5eLHZZdKe4AvBPoPP3YKbCb95jgyJYHF, address:195.240.94.249:28967): rpc: tcp connector failed: rpc: dial tcp 195.240.94.249:28967: connect: connection timed out; ecclient: upload failed (node:1b6J8TYtkPANoMGBxaBSFpJLzsyFpK5rdveL8yHAjuBytrVXbB, address:51.79.237.21:28995): rpc: tcp connector failed: rpc: dial tcp 51.79.237.21:28995: connect: connection timed out; ecclient: upload failed (node:12DgiofVsFEMjht6zph6o8zkoVCmVQAnAh3rsYVVRacvwisF5J1, address:181.41.215.19:28010): rpc: tcp connector failed: rpc: dial tcp 181.41.215.19:28010: connect: connection timed out; ecclient: upload failed (node:12SBghngWCfjWbDpWB38drMhUVydc4yYj9m6ezwfms3dyymdocV, address:147.158.41.62:28967): rpc: tcp connector failed: rpc: dial tcp 147.158.41.62:28967: connect: connection timed out
failed to upload part 467: uplink: stream: context canceled; ecclient: upload cancelled by user
Hello @rod,
Please try to reboot your router. If you have used WiFi try to use a wired connection instead.
You may also use rclone, it has a retry function for unstable network: Rclone - Storj DCS Docs
However, if your router would be overloaded with number of connections again, perhaps you would need to use an integration via GatewayMT: Rclone Hosted Gateway - Storj DCS Docs (please be aware that the Storj-hosted S3-Compatible Gateway uses server-side encryption)
