Hi, new to Storj. I’m trying to do my first upload from the command line but I get this error:
PS C:\temp> .\uplink.exe cp C:\Users\charl\Desktop\test.txt sj://homestead
Created sj://homestead/test.txt
.\uplink.exe : 0 B / 33 B [___________________________________________________________________________] 0.00% ? p/s33 B / 33 B
[----------------------------------------------------------------------->] 100.00% ? p/s33 B / 33 B
[-------------------------------------------------------------------->] 100.00% 55 B p/s33 B / 33 B
[-------------------------------------------------------------------->] 100.00% 51 B p/s33 B / 33 B
[---------------------------------------------------------------------] 100.00% 25 B p/s
At line:1 char:1
+ .\uplink.exe cp C:\Users\charl\Desktop\test.txt sj://homestead
+ CategoryInfo : NotSpecified: (0 B / 33 B [___...00.00% 25 B p/s:String) [], RemoteException
+ FullyQualifiedErrorId : NativeCommandError
I just created a small test file. The connection works. I could list the buckets and create new ones. I just cant seem to copy or put.
Any idea what my problem could be?
Charlie
What is the upload speed in your location? You can use speedtest.net to check it.
Do you use some restrictive firewall on your Windows PC or on your router or in between?
If you use a firewall - is it allows connections from your Windows PC to any destination and port?
Please, give me result of the command:
Get-Acl C:\Users\charl\Desktop\test.txt
And this one
.\uplink.exe ls sj://homestead
Please try to upload with --log.level debug option and post results.
So it looks like the file was created last night, despite the error.
When I do a cp today with the debug option I get this:
PS C:\temp> .\uplink.exe cp C:\Users\charl\Desktop\test3.txt sj://homestead --log.level debug
.\uplink.exe : 07:16:27.758 INFO Configuration loaded
At line:1 char:1
+ .\uplink.exe cp C:\Users\charl\Desktop\test3.txt sj://homestead --log ...
+ CategoryInfo : NotSpecified: (07:16:27.758 INFO Configuration loaded:String) [], RemoteException
Location: C:\Users\charl\AppData\Roaming\Storj\Uplink\config.yaml
07:16:27.758 INFO Anonymized tracing enabled
07:16:27.779 DEBUG started
07:16:27.779 DEBUG debug server listening on 127.0.0.1:55624
Created sj://homestead/test3.txt
17 B / 17 B [----------------------------------------------------------------------->] 100.00% ? p/s17 B / 17 B
[--------------------------------------------------------------------] 100.00% 111 B p/s07:16:28.215 DEBUG stopped
My internet connection is only 20MB but I get the same behavior when working off my hotspot so I don’t think it is my router. The files seem to be copying but the output from the commands makes me think its not working.
