Upload rejected, too many requests since 0.24.5
Since update 0.24.5 I have a lot upload rejected, too many requests.
even if i change the yaml configuration with any number: 2, 5, 10 i still have this problem.
I understand nothing
all upload rejected why ?
i believe that would be the concurrency setting in the configuration file. Set it higher, or remove it to set no upper limit.
storage2.max-concurrent-requests: 7
https://documentation.storj.io/resources/frequently-asked-questions
i have remove it, always the same problem, all my uploads are rejected
Then try adding it back again and see if it helps
nothing all upload rejected, only download ok
Is it a network connected drive?
Please check your free space and your write access to the data.
since the update I have this problem.
Add storage2.max-concurrent-requests
