Upload via uplink stuck
It looks like storj can’t be used for backup.
2020-02-28T20:24:36.299+0100 WARN Failed deleting segment {“path”: “testtest/vm-101-disk-0.raw”, “Segment Index”: 1, “error”: “segment error: metainfo error: rpccompat: EOF”, “errorVerbose”: “segment error: metainfo error: rpccompat: EOF\n\tstorj.io/common/rpc.Dialer.dialTransport:262\n\tstorj.io/common/rpc.Dialer.dial.func1:216\n\tstorj.io/common/rpc/rpcpool.(*Conn).newConn:114\n\tstorj.io/common/rpc/rpcpool.(*Conn).getConn:143\n\tstorj.io/common/rpc/rpcpool.(*Conn).Invoke:179\n\tstorj.io/common/pb.(*drpcMetainfoClient).BeginDeleteSegment:5556\n\tstorj.io/uplink/metainfo.(*Client).BeginDeleteSegment:936\n\tstorj.io/uplink/storage/segments.(*segmentStore).Delete:139\n\tstorj.io/uplink/storage/streams.(*streamStore).cancelHandler:538\n\tstorj.io/uplink/storage/streams.(*streamStore).Put.func1:107\n\tstorj.io/uplink/storage/streams.(*streamStore).Put:214\n\tstorj.io/uplink/storage/streams.(*shimStore).Put:49\n\tstorj.io/uplink/stream.NewUpload.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
42.06 GiB / 500.00 GiB [--------->] 8.41% 837.61 KiB p/s2020-02-28T20:24:49.582+0100 WARN Failed deleting segment {“path”: “testtest/vm-101-disk-0.raw”, “Segment Index”: 4, “error”: “segment error: metainfo error: context canceled”, “errorVerbose”: “segment error: metainfo error: context canceled\n\tstorj.io/uplink/metainfo.(*Client).BeginDeleteSegment:938\n\tstorj.io/uplink/storage/segments.(*segmentStore).Delete:139\n\tstorj.io/uplink/storage/streams.(*streamStore).cancelHandler:538\n\tstorj.io/uplink/storage/streams.(*streamStore).Put.func1:107\n\tstorj.io/uplink/storage/streams.(*streamStore).Put:214\n\tstorj.io/uplink/storage/streams.(*shimStore).Put:49\n\tstorj.io/uplink/stream.NewUpload.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-02-28T20:24:49.727+0100 WARN Failed deleting segment {“path”: “testtest/vm-101-disk-0.raw”, “Segment Index”: 5, “error”: “segment error: metainfo error: context canceled”, “errorVerbose”: “segment error: metainfo error: context canceled\n\tstorj.io/uplink/metainfo.(*Client).BeginDeleteSegment:938\n\tstorj.io/uplink/storage/segments.(*segmentStore).Delete:139\n\tstorj.io/uplink/storage/streams.(*streamStore).cancelHandler:538\n\tstorj.io/uplink/storage/streams.(*streamStore).Put.func1:107\n\tstorj.io/uplink/storage/streams.(*streamStore).Put:214\n\tstorj.io/uplink/storage/streams.(*shimStore).Put:49\n\tstorj.io/uplink/stream.NewUpload.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
_______] 8.41% 1 B p/s
After repeated attempts, none were successful. At best, 300Gb of raw data was sent, or just 100GB of the 500 required. So storj not usable for doing backups.
@littleskunk @Alexey
I have actuall the same Problem. Tardigarde has for me no Use Case. QNAP Backup does not work nor Duplicati.Uplod speed is less.
I hope and wish the team the best to really launch a Version which have any real world use case.
What is your current limit of storage?
1TB
