With uptime kuma (uptime robot engine) I can check http keyword. I’m monitoring http page of my nodes for keyword “true” for in “AllHealthy”.
Can I be safe with that? If a node starting to fail audits it turn to false?
Why search for keyword when you have an option to check TCP Port ?
Use the port you used in your config to monitor node’s uptime.
Edit: you can get the same features from uptime robot too.
Because is not just a port. Keyword (“AllHealthy”: true) give you a better monitor of your node. Quic is ok. Uptime is ok. It’s not just up and running… and maybe failing audits ![]()
If any error just happening (for example - not trusted satellites), it would turn to false.
So not necessarily only failed audits.
Can I find a list of “triggers” for false value?
any error in your log can trigger it.
Yes. I meant that. I’m using http keyword monitor
