As if using the same email I think it is not a problem right?
But in the case of using the same ETH address for the different nodes, is it allowed?
In payments would the 4-5 payments arrive together or for each separate node?
Thanks
Thanks
I am using the same email and ETH address on all my nodes.
Payments are per node, per satellite (I am currently getting 42 Payments for 7 nodes)
You must use the same wallet for all your nodes accordingly Storage Node Operator Terms and Conditions
