I am implementing Zabbix monitoring of my storage nodes and I can do it entirely in Zabbix with one issue: Zabbix can’t represent the number of bytes as floating point (it’s out of range). As a result, I have to represent this as an integer.
However, I can’t just use the raw numbers that come back for storage since they are in GB, so I need to multiply by 1024 * 1024 * 1024 to convert from GB to B (Zabbix does strange things when the unit is GB, displaying KGB instead of TB for example). Unfortunately, the integer truncation happens before the multiplication meaning I’ll only ever see whole-GB values and never fractional GBs in charts.
A simple solution to this would be to unify on bytes as the unit for the dashboard API. Currently, the units are mixed which already causes confusion:
- Data using GB as the unit:
diskSpace
bandwidth.used
bandwidth.available
- Data using B as the unit:
bandwidth.egress
bandwidth.ingress
This mixing of units is strange as it is. Calculations become a lot easier if everything is represented in bytes. There’s no precision loss as a result of using floating-point, and we don’t have to try to infer the units in use.
I may write a simple proxy to perform this conversion for me before Zabbix sees the data, but it would be great if this could be corrected so that a proxy isn’t required to pull consistent data.
