I have tried the options suggested in the documentation for recreating the dbs after power outage. All of them are recreated except the used_serial.db. The file exists and I see no permissions issues.
This is running on Ubuntu docker. I dismounted drive and checked for errors. Came up clean.
This is my 1st node and had been running for less than 30 days.
Suggestions?
error logs:
Error: Error opening database on storagenode: database: used_serial opening file “config/storage/used_serial.db” failed: unable to open database file: no such file or directory
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:347
storj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:324
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:299
storj.io/storj/storagenode/storagenodedb.OpenExisting:266
main.cmdRun:65
main.newRunCmd.func1:33
storj.io/common/process.cleanup.func1.4:393
storj.io/common/process.cleanup.func1:411
github.com/spf13/cobra.(*Command).execute:983
github.com/spf13/cobra.(*Command).ExecuteC:1115
github.com/spf13/cobra.(*Command).Execute:1039
storj.io/common/process.ExecWithCustomOptions:112
main.main:31
runtime.main:267
