Hey guys,
quick question: I had a SSD failure (where my DBs where stored).
I could restore everything despite my “used_serial.db”… don’t know why there is a backup of everything, but this DB
Is my node now doomed or can I replace it from another node or regenerate it somehow?
Regards
Alexey
August 31, 2020, 8:30am
2
Stop the storagenode
Execute either with a local sqlite3
binary or with a docker version (how to run a docker version described in https://support.storj.io/hc/en-us/articles/360029309111 ), replace the /path/to/
to your actual path
sqlite3 /path/to/used_serial.db
When you see the sqlite>
prompt, execute the script:
CREATE TABLE versions (version int, commited_at text);
.exit
Start the storagenode
Check your logs
Thanks for the fast response.
After uploading the freshly created DB I get these:
I could use your tutorial from another thread:
now the node is starting back up, but the “used Disc Space” is shown incorrect…no problem for me, if I get paid correctly
That table is no longer there in the latest version. Make sure you update your node.
Good to see it’s up and running again though!
Which table do you mean?
My node is @ v1.10.1 (docker)…I didn’t get a newer yet.
The used_serial_ table.
But I just noticed that the error was thrown by the migration step. So, that should have automatically gotten rid of it again.
If you’re on the latest version now, you’re all good. Please disregard my previous message.
