Used Storage wrong calculated
Hi,
My Storj node dashboard reports 4.4TB of storage used:
  • 3.7TB Other
  • 91GB Trash
  • 0.5TB Used reclaimable
However, when I check the actual disk folder with du -sh, it only shows 4TB. There’s a ~400GB gap. It appears that “used reclaimable” doesn’t actually exist on disk. Is this a bug?
Is this just a base2/base10 thing? Add a --si flag to du and you should see the larger value.
yep:
4.4/1.024/1.024/1.024/1.024 = 4.0
thanks a lot … :slight_smile: now everything makes sense.
