Node is still running and PC is OK. Overused shows 2.06TB
If you’ve disabled the file walker on startup, you should enable and run it at least once. There was an issue that didn’t update trash stats after deleting on a previous version. Doing the above fixes the stats.
Is the lazyfilewalker fixed now?
I believe so, but the fix alone won’t update the stats. You need to run the file walker at startup at least once.
I did not/have not disabled file walker. Will restart the PC to see if that fixes the problem after allowing time for the file walker to do its thing.
After 2 days the issue has gone away. Numbers look ok now.
