Usingh Storj for HLS, MPEG-DASH etc VODS
Hi all,
I am trying to see if I can use Storj for playing videos that have been encoded using HLS/MPEG-DASH. But the issue is getting the “folder” for the players to get the rest of the files from. For example you would link the index file and the player will look for the rest of the files in the same folder. But it looks like using the “share link” you have to append the “download=1” which I can’t do currently. Any suggestions to this?
Edit: It does look like I have asked a similar question before however when I tried it (http://link.tardigradeshare.io/raw…) I get access denied when using it through a website?
Thanks
I got it working eventually. Something might have gone wrong during the upload etc.
Hello, how did you achieve it? I’m interested.
I also managed it, only in the master.m3u8 I changed .ts to .ts?download=1
and so in the HLS player just put the url of the Storj folder.
