guide https://documentation.storj.io/dependencies/port-forwarding says
You’ll then be prompted for your NoIP username and password, as well as the hostnames you wish to update.
however I am presented with two questions after running /usr/local/bin/noip2 -C
ubuntu@ubuntu:~/noip-2.1.9-1$ sudo /usr/local/bin/noip2 -C
Auto configuration for Linux client of no-ip.com.
Please enter the login/email string for no-ip.com xyz@gmail.com
Please enter the password for user 'xyz@gmail.com' *********
Only one host [mynode.hopto.org] is registered to this account.
It will be used.
Please enter an update interval:[30] 30
Do you wish to run something at successful update?[N] (y/N) n
New configuration file '/usr/local/etc/no-ip2.conf' created.
please advise. thanks.
