Verify Wallet on Node
Good day,
Would like to find out where i can verify my wallet address?
I edit my config.yaml recently to add the concurrent connections to test some performance and noticed this:
operator email address
kademlia.operator.email: “”
operator wallet address
kademlia.operator.wallet: “”
Is this normal to be empty?
Is there any way to verify my wallet im using?
Hello @Cuz_Moh,
The environment variables specified in the docker run command have a precedence above options in the config.yaml file. This file usually autogenerated and could not have all options, because you specified them in the docker run.
You can see your docker run environment variables by command
docker inspect storagenode -f "{{.Config.Env}}"
