Very low traffic and too many failures of upload. v0.31.12
Until the other day, the upload success rate was 90%.
However
suddenly, upload failures increased.
After updating to v0.31.12, the upload success rate is 0%.
Are these behaviors correct?
Please tell us about your stat.
$ ./successrate.sh storagenode
Successful: 1
Recoverable failed: 0
Unrecoverable failed: 0
Success Rate Min: 100.000%
Success Rate Max: 100.000%
Successful: 1
Failed: 0
Success Rate: 100.000%
Successful: 0
Rejected: 0
Failed: 25
Acceptance Rate: 0.000%
Success Rate: 0.000%
Successful: 0
Failed: 0
Successful: 4
Failed: 3
Success Rate: 57.143%
Can’t tell about the success rate because i don’t have the script but i noticed lower traffic (in 8 hours I made 70 mb ingress lol and 200mb egress, my avg was 2.5gb ingress and 1gb egress - i’m still being vetted)
This may be due to WARNING: Full nodes receiving data
Is this issue already fixed in v0.31.12?
As far as i know, yes they fixed it
All my upload in logs is failed (v0.31.12). I think it is turned off on satellite.
All my upload is failed too.
Is this caused by satellites?
The developer said yesterday that it will stop functioning until the bug is fixed to reduce network load.
They have not been unlocked yet?
https://status.tardigrade.io/
here you can check satellite status and everything seems ok
I’m facing the same issue, here’s my logs from success rate script
Successful: 6
Successful: 53
Failed: 0
Successful: 25
Rejected: 0
Failed: 94
Acceptance Rate: 100.000%
Success Rate: 21.008%
Successful: 0
Failed: 0
Successful: 7
Failed: 18
Success Rate: 28.000%
For now we have stopped several test downloads and uploads, so it’s expected that you are getting less traffic.
Successful: 252
Successful: 7187
Failed: 52
Success Rate: 99.282%
Successful: 204
Rejected: 0
Failed: 906
Success Rate: 18.378%
Successful: 1216
Failed: 1
Success Rate: 99.918%
Successful: 143
Failed: 738
Success Rate: 16.232%
Just want to add there is nothing wrong with your nodes. Traffic patterns are not constant and depend on customer use. And recently we’ve been really spoiled with a lot of additional test traffic from Storjlabs. Drops in successrates can easily be related to different customers at longer distances from your node taking over from the Storj test traffic. It’s not a problem with your node. These scripts just give an indication of node performance right now, but should not be used to determine whether your node works correctly or not.
after the 0.31.12 update
The volume is not large after turning off the tests, but the rating suits me. I will continue to collect statistics from this, more real moment.
log rate analizer_01
