veeting process is going on each satelite independently, if there will be more satelites. As new satelite acure, it will start his own veeting process and it not somehow change that you are veeted on ather satelits, just that satelit will give you smaller part of data, until veeting over.
Hello, about 20 hours ago I created a new node, which until now works without problems, my doubt is that in all this time I have not had any audit. Do I have to wait more hours?
Correct, it’s random.
usually it take around month or more to get vetted at 100+
ok… thanks! for the answer
Correct answer. And it’s ALL satellites that does vetting.
This has been discussed here thousands of times, its not that hard to search the forum
can a 26 day old node get fully vetted if it runs out of disk space with only four of the six satellites fully vetted
It can, if it has the data from customers of satellite in question.
Is the node operator notified when the node passes the vetting period?
cheers
No there is no such information. If you don’t want to start another node on the same PC it also probably does not matter.
Currently the only way to see vetting progress and whether is finished is to pluck it from the databases yourself. Now that may not be something you want to manually do. There is another option, which is to let the earnings calculator I made do that for you. Added bonus is that it makes some effort to translate the non-linear amount of audits into a linear progress percentage. That way you get a better idea about how far along you are in the process time wise. The calculator offers a lot more info, this is just one feature, but you can find more info in the relevant topic here: Earnings calculator (Update 2021-06-11: v10.2.1 - Detailed payout information: Now includes comparison to actual payout, postponed payouts due to threshold and transaction links!)
Thanks! this is great and very useful!
Audits can be slow early on and they are small. Repair egress won’t happen for a few months, since all your pieces are new and the segments won’t need repair until other nodes go offline. So that’s normal too. It might be that nodes in vetting are no longer selected for repair uploads, which could explain no ingress repair. I don’t see anything in your screenshot that would worry me.
@BrightSilence , thank you for reply & your explainations.
All is clear ![]()
Hi, you read this:
I started a new node a few days back and I see the vetting process going fast.
Even the monthly bandwidth ingress shows like 30% of a vetted node.
Is the allocated ingress for vetting increased from 5%?
Or there are not so many unvetted nodes these days?
122.29GB ingress on new unvetted node
458.64GB ingress on old vetted node
It has been at 1% for a long time now, I think?
We will see, when it would finish the vetting process. Please, keep us updated.
Maybe Earnings calculator (Update 2024-07-28: v14.1.0 - Now shows garbage collection progress! - Detailed earnings info and health status of your node, including vetting progress and garbage collection status) would need an update.
The ingress for the unvetted node for this month is still 33% of the vetted nodes.
Ingress unvetted: 271GB
Ingress vetted: 829GB
Day 13: EU1 done.
Day 15: AP1 done.
Day 22: US1 done.
