Vetting check on truenas scale
Hello is there a way to check vetting on truenas scale i see some code that you can use but i think is only for windows?
Welcome to the forum @lgorrin18 !
Which code did you see ?
I haven’t use any just wondering if it was possible from truenas
I meant by this part of your statement. I understand you didn’t use it as its Windows based. A link would help so we can help you better.
Hello @lgorrin18,
There is no Windows code to check the vetting. There is a Community script, which could also show the vetting percentage:
