You need to enable virtualization in the BIOS.
You may also try to install WSL2 as an engine for docker, but after enabling virtualization in the BIOS.
If you wanna install docker on that laptop you will need to install linux and then you don’t need to worry about enabling virtualization or worry about the cpu supporting it. But I would just install storj on windows the easy with the setup.
In case of Linux OS you will not need to have a VM and virtualization, docker working natively in Linux.
If you still want to have a virtualization enabled, you still need to find an option in your BIOS, which mention Virtualization, or CPU features or something like this, it could also mention VT-x or VT.
Please also note - the Hyper-V is available only for Windows Pro, but wsl2 can be installed on Windows Home too.
