Este es el log
2020-07-09T23:28:08.424+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2020-07-09T23:28:08.551+0200 INFO Operator email {“Address”: “@gmail.com”}
2020-07-09T23:28:08.551+0200 INFO Operator wallet {“Address”: “0xC1E4aD79C6F4FD21C2e09a09639E57D002552Dc5”}
2020-07-09T23:28:10.832+0200 INFO Telemetry enabled
2020-07-09T23:28:13.566+0200 INFO db.migration Database Created {“version”: 42}
2020-07-09T23:28:14.229+0200 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-07-09T23:28:15.147+0200 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-07-09T23:28:15.147+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-09T23:28:15.148+0200 INFO Node 12AARCEYkKHis6abfB3VWyr9Q8Thk61oiGxiXBDzXsraWpzhQUQ started
2020-07-09T23:28:15.148+0200 INFO Public server started on [::]:28967
2020-07-09T23:28:15.148+0200 INFO Private server started on 127.0.0.1:7778
2020-07-09T23:28:15.149+0200 INFO trust Scheduling next refresh {“after”: “6h37m32.438237477s”}
2020-07-09T23:28:58.034+0200 INFO Stop/Shutdown request received.
2020-07-09T23:29:00.144+0200 FATAL Unrecoverable error {“error”: “debug: http: Server closed”, “errorVerbose”: “debug: http: Server closed\n\tstorj.io/private/debug.(*Server).Run.func2:108\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-07-09T23:30:00.820+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2020-07-09T23:30:01.008+0200 INFO Operator email {“Address”: “@gmail.com”}
2020-07-09T23:30:01.008+0200 INFO Operator wallet {“Address”: “0xC1E4aD79C6F4FD21C2e09a09639E57D002552Dc5”}
2020-07-09T23:30:03.459+0200 INFO Telemetry enabled
2020-07-09T23:30:03.603+0200 INFO db.migration Database Version {“version”: 42}
2020-07-09T23:30:05.554+0200 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-07-09T23:30:06.864+0200 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-07-09T23:30:06.915+0200 INFO Node 12AARCEYkKHis6abfB3VWyr9Q8Thk61oiGxiXBDzXsraWpzhQUQ started
2020-07-09T23:30:06.915+0200 INFO Public server started on [::]:28967
2020-07-09T23:30:06.915+0200 INFO Private server started on 127.0.0.1:7778
2020-07-09T23:30:06.945+0200 INFO trust Scheduling next refresh {“after”: “3h31m47.912264316s”}
2020-07-09T23:30:06.980+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-09T23:33:22.434+0200 INFO Stop/Shutdown request received.
2020-07-09T23:33:22.872+0200 FATAL Unrecoverable error {“error”: “debug: http: Server closed”, “errorVerbose”: “debug: http: Server closed\n\tstorj.io/private/debug.(*Server).Run.func2:108\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-07-09T23:33:23.050+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2020-07-09T23:33:23.091+0200 INFO Operator email {“Address”: “@gmail.com”}
2020-07-09T23:33:23.091+0200 INFO Operator wallet {“Address”: “0xC1E4aD79C6F4FD21C2e09a09639E57D002552Dc5”}
2020-07-09T23:33:23.966+0200 INFO Telemetry enabled
2020-07-09T23:33:23.973+0200 INFO db.migration Database Version {“version”: 42}
2020-07-09T23:33:25.017+0200 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-07-09T23:33:25.891+0200 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-07-09T23:33:25.891+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-09T23:33:25.892+0200 INFO Node 12AARCEYkKHis6abfB3VWyr9Q8Thk61oiGxiXBDzXsraWpzhQUQ started
2020-07-09T23:33:25.892+0200 INFO Public server started on [::]:28967
2020-07-09T23:33:25.892+0200 INFO Private server started on 127.0.0.1:7778
2020-07-09T23:33:25.892+0200 INFO trust Scheduling next refresh {“after”: “7h11m49.707305104s”}
2020-07-09T23:52:07.666+0200 INFO Stop/Shutdown request received.
2020-07-09T23:52:08.133+0200 FATAL Unrecoverable error {“error”: “debug: http: Server closed”, “errorVerbose”: “debug: http: Server closed\n\tstorj.io/private/debug.(*Server).Run.func2:108\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-07-09T23:52:08.263+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2020-07-09T23:52:08.302+0200 INFO Operator email {“Address”: “@gmail.com”}
2020-07-09T23:52:08.302+0200 INFO Operator wallet {“Address”: “0xC1E4aD79C6F4FD21C2e09a09639E57D002552Dc5”}
2020-07-09T23:52:09.093+0200 INFO Telemetry enabled
2020-07-09T23:52:09.100+0200 INFO db.migration Database Version {“version”: 42}
2020-07-09T23:52:10.105+0200 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-07-09T23:52:11.038+0200 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-07-09T23:52:11.038+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-09T23:52:11.039+0200 INFO Node 12AARCEYkKHis6abfB3VWyr9Q8Thk61oiGxiXBDzXsraWpzhQUQ started
2020-07-09T23:52:11.039+0200 INFO Public server started on [::]:28967
2020-07-09T23:52:11.039+0200 INFO Private server started on 127.0.0.1:7778
2020-07-09T23:52:11.039+0200 INFO trust Scheduling next refresh {“after”: “6h13m10.110540037s”}
2020-07-09T23:59:18.326+0200 INFO Stop/Shutdown request received.
2020-07-09T23:59:20.405+0200 FATAL Unrecoverable error {“error”: “debug: http: Server closed”, “errorVerbose”: “debug: http: Server closed\n\tstorj.io/private/debug.(*Server).Run.func2:108\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-07-10T00:00:18.646+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2020-07-10T00:00:18.773+0200 INFO Operator email {“Address”: “4storj@gmail.com”}
2020-07-10T00:00:18.773+0200 INFO Operator wallet {“Address”: “0xC1E4aD79C6F4FD21C2e09a09639E57D002552Dc5”}
2020-07-10T00:00:20.097+0200 INFO Telemetry enabled
2020-07-10T00:00:20.110+0200 INFO db.migration Database Version {“version”: 42}
2020-07-10T00:00:21.819+0200 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-07-10T00:00:23.027+0200 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-07-10T00:00:23.027+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T00:00:23.027+0200 INFO Node 12AARCEYkKHis6abfB3VWyr9Q8Thk61oiGxiXBDzXsraWpzhQUQ started
2020-07-10T00:00:23.027+0200 INFO Public server started on [::]:28967
2020-07-10T00:00:23.027+0200 INFO Private server started on 127.0.0.1:7778
2020-07-10T00:00:23.027+0200 INFO trust Scheduling next refresh {“after”: “4h31m26.491635401s”}
2020-07-10T01:00:23.037+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T02:00:23.032+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T03:00:23.036+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T04:00:23.037+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T04:31:50.151+0200 INFO trust Scheduling next refresh {“after”: “6h24m27.66209448s”}
2020-07-10T05:00:23.032+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T06:00:23.042+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T07:00:23.028+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T08:00:23.028+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T09:00:23.030+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T10:00:23.066+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T10:56:18.453+0200 INFO trust Scheduling next refresh {“after”: “5h19m37.708089209s”}
2020-07-10T11:00:23.030+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T11:48:54.404+0200 INFO Stop/Shutdown request received.
2020-07-10T11:48:55.975+0200 FATAL Unrecoverable error {“error”: “debug: http: Server closed”, “errorVerbose”: “debug: http: Server closed\n\tstorj.io/private/debug.(*Server).Run.func2:108\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-07-10T13:35:23.200+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2020-07-10T13:35:23.283+0200 INFO Operator email {“Address”: “@gmail.com”}
2020-07-10T13:35:23.284+0200 INFO Operator wallet {“Address”: “0xC1E4aD79C6F4FD21C2e09a09639E57D002552Dc5”}
2020-07-10T13:35:24.516+0200 INFO Telemetry enabled
2020-07-10T13:35:24.523+0200 INFO db.migration Database Version {“version”: 42}
2020-07-10T13:35:25.666+0200 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-07-10T13:35:26.567+0200 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-07-10T13:35:26.567+0200 INFO bandwidth Performing bandwidth usage rollups
2020-07-10T13:35:26.568+0200 INFO Node 12AARCEYkKHis6abfB3VWyr9Q8Thk61oiGxiXBDzXsraWpzhQUQ started
2020-07-10T13:35:26.568+0200 INFO Public server started on [::]:28967
2020-07-10T13:35:26.568+0200 INFO Private server started on 127.0.0.1:7778
2020-07-10T13:35:26.569+0200 INFO trust Scheduling next refresh {“after”: “4h38m59.866592974s”}
