Waiting for running update to be finished
Seeing this message in my Watchtower logs.
Looking at prior posts it’s not clear what this is telling me:
  • Watchtower believes there is an upgrade in progress (or an upgrade failed during an upgrade), node operator intervention may be required. (This feels like how I and many others are interpreting this message)
  • Watchtower knows there is an update, but won’t install it on your node yet to ensure network stability.
  • Watchtower knows there is an update available, but not for Watchtower users yet
  • Nothing - Watchtower is happy.
  • Something else?
(I don’t see any logs attached?)
It’s literally just the following…
03/01/2025 8:20:37 AM
time="2025-03-01T13:20:37Z" level=info msg="Waiting for running update to be finished..."
… been the case since day 1 of V3
@Alexey - Can you confirm this is a known defect. While I appreciate it may just be a red herring (and posted as an INFO, not WARN or ERROR), it’s something the community should know exists and can safely ignore until a watchtower developer can improve the case statement that’s resulting this confusing messaging.
I didn’t think watchtower was part of an install anymore: since the node performs its own internal upgrades? (like is this a message from a deprecated component?)
No, it’s not a known problem/bug, so must be something local.
Currently I am showing :
v1.122.9 with “Your node is up to date. Current minimum version: v1.122.9”
Is this what’s currently being deployed, or do I need to redeploy the watchtower container on my Ubuntu node?
Also - @Roxor suggested watchtower is no longer needed - can anyone confirm?
I dont run watchtower and my nodes auto update
Are you on Linux or Windows?
Looks like I have the latest container pulled down, I guess I need to make sure that’s the container version that’s deployed.
sudo docker pull storjlabs/storagenode:latest
[sudo] password for cpare:
latest: Pulling from storjlabs/storagenode
Digest: sha256:21ca0ac819d1d66240830d28097eeb693923e51383aa3bb07bf823f9fad1f6e9
Status: Image is up to date for storjlabs/storagenode:latest
docker.io/storjlabs/storagenode:latest
It will get an update when the time to come, you need to wait.
