Windows Config includes both values so I am not sure how to correct the errors. Anyone ever see this before? Thanks!
Is this docker or GUI for Windows ?
Windows GUI however, it’s a manual installation as this is my second node on the machine.
Try deleting config.yaml
for this second node and restart your node.
The first node is operating correctly, it’s the second node that won’t start due to issues with email and wallet.
Yes try deleting config.yaml
for THIS SECOND node. Then start it up.
Can you post pic of start command in service of second node?
