Watchtower errors
Hi!
Looks like got some problem with watchtower update:
time=“2022-11-04T10:04:03Z” level=info msg=“Unable to update container /watchtower. Proceeding to next.”
time=“2022-11-05T08:12:27Z” level=info msg=“Unable to update container /storagenode2. Proceeding to next.”
time=“2022-11-05T08:12:27Z” level=info msg=“Unable to update container /storagenode3. Proceeding to next.”
time=“2022-11-05T08:12:27Z” level=info msg=“Unable to update container /storagenode5. Proceeding to next.”
time=“2022-11-05T08:12:27Z” level=info msg=“Unable to update container /storagenode1. Proceeding to next.”
time=“2022-11-05T08:12:27Z” level=info msg=“Unable to update container /watchtower. Proceeding to next.”
time=“2022-11-05T10:27:08Z” level=info msg=“Waiting for running update to be finished…”
time=“2022-11-06T05:29:51Z” level=info msg=“Waiting for running update to be finished…”
And the following in node:
2022-11-06T05:03:30.249Z INFO Downloading versions. {“Process”: “storagenode-updater”, “Server Address”: “https://version.storj.io”}
2022-11-06T05:03:30.470Z ERROR Error retrieving version info. {“Process”: “storagenode-updater”, “error”: “version checker client: Get "https://version.storj.io": EOF”, “errorVerbose”: “version checker client: Get "https://version.storj.io": EOF\n\tstorj.io/storj/private/version/checker.
(*Client).All:68\n\tmain.loopFunc:21\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tmain.cmdRun:136\n\tstorj.io/private/process.cleanup.func1.4:378\n\tstorj.io/private/process.cleanup.func1:396\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:20\n\truntime.main:255”}
2022-11-06T05:18:30.263Z INFO Downloading versions. {“Process”: “storagenode-updater”, “Server Address”: “https://version.storj.io”}
2022-11-06T05:18:30.482Z ERROR Error retrieving version info. {“Process”: “storagenode-updater”, “error”: “version checker client: Get "https://version.storj.io": EOF”, “errorVerbose”: “version checker client: Get "https://version.storj.io": EOF\n\tstorj.io/storj/private/version/checker.(*Client).All:68\n\tmain.loopFunc:21\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tmain.cmdRun:136\n\tstorj.io/private/process.cleanup.func1.4:378\n\tstorj.io/private/process.cleanup.func1:396\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:20\n\truntime.main:255”}
2022-11-06 05:29:51,565 WARN received SIGTERM indicating exit request
2022-11-06 05:29:51,566 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
2022-11-06T05:29:51.566Z INFO Got a signal from the OS: “terminated” {“Process”: “storagenode-updater”}
2022-11-06 05:29:51,568 INFO stopped: storagenode-updater (exit status 0)
2022-11-06 05:29:51,964 INFO stopped: storagenode (exit status 0)
2022-11-06 05:29:51,965 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
2022-11-06 05:30:42,338 INFO Set uid to user 0 succeeded
2022-11-06 05:30:42,348 INFO RPC interface ‘supervisor’ initialized
2022-11-06 05:30:42,348 INFO supervisord started with pid 1
2022-11-06 05:30:43,350 INFO spawned: ‘processes-exit-eventlistener’ with pid 11
2022-11-06 05:30:43,351 INFO spawned: ‘storagenode’ with pid 12
2022-11-06 05:30:43,352 INFO spawned: ‘storagenode-updater’ with pid 13
2022-11-06T05:30:43.456Z INFO Configuration loaded {“Process”: “storagenode-updater”, “Location”: “/app/config/config.yaml”}
2022-11-06T05:30:43.456Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “server.address”}
2022-11-06T05:30:43.456Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.wallet”}
2022-11-06T05:30:43.456Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.wallet-features”}
2022-11-06T05:30:43.456Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “contact.external-address”}
2022-11-06T05:30:43.456Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “operator.email”}
2022-11-06T05:30:43.456Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “server.private-address”}
2022-11-06T05:30:43.456Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “storage.allocated-bandwidth”}
2022-11-06T05:30:43.456Z INFO Invalid configuration file key {“Process”: “storagenode-updater”, “Key”: “storage.allocated-disk-space”}
2022-11-06T05:30:43.491Z INFO Anonymized tracing enabled {“Process”: “storagenode-updater”}
2022-11-06T05:30:43.605Z INFO Running on version {“Process”: “storagenode-updater”, “Service”: “storagenode-updater”, “Version”: “v1.63.1”}
2022-11-06T05:30:43.605Z INFO Downloading versions. {“Process”: “storagenode-updater”, “Server Address”: “https://version.storj.io”}
2022-11-06T05:30:43.823Z ERROR Error retrieving version info. {“Process”: “storagenode-updater”, “error”: “version checker client: Get "https://version.storj.io": EOF”, “errorVerbose”: “version checker client: Get "https://version.storj.io": EOF\n\tstorj.io/storj/private/version/checker.(*Client).All:68\n\tmain.loopFunc:21\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tmain.cmdRun:136\n\tstorj.io/private/process.cleanup.func1.4:378\n\tstorj.io/private/process.cleanup.func1:396\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:20\n\truntime.main:255”}
Delete the watchtower container in Docker, then in PowerShell:
docker pull storjlabs/watchtower
and got the following message:
Using default tag: latest
Error response from daemon: Get "https://registry-1.docker.io/v2/": EOF```
You have problems with your network configuration on this server, it cannot retrieve even a small file.
Try to wsl --shutdown from PowerShell, the Docker Desktop should suggest to restart the docker subsystem - agree with it, then try to pull the image.
If it doesn’t help - try to reboot.
If you do not use wsl2 in the Docker desktop, then try to restart the docker subsystem from the Docker desktop application (it’s in the debug section).
I’ve tried:
del the watchtower image->wsl --shutdown->Docker restart->pull the image by docker pull storjlabs/watchtower->get the same error;
del the watchtower image->reboot pc->->wsl --shutdown->Docker restart->pull the image by docker pull storjlabs/watchtower->get the same error.
the Nodes itself in online status in Node Dashboard
unfortunately it’s a network error
  1. Try to restart the router
  2. try to reset the network
    in the elevated PowerShell
wsl --shutdown
netsh winsock reset
netsh int ip reset all
netsh winhttp reset proxy
ipconfig /flushdns
netsh winsock reset
shutdown /r
  1. Try to reinstall the docker desktop and related VMs:
    Uninstall the docker desktop. If you used wsl2, uninstall the wsl2 distro, install wsl2 subsystem again, install the distro back. And install the docker desktop back.
it’s just usual normal node activity:
piecestore download started
piecestore downloaded
The problem in watchtower itself or in dependencies of watchtower container.
It appeared after WIN 22H2 update that I’ve made yesterday.
The problem is much worse - it cannot download from docker hub and a small file from version.storj.io
so, nodes will be affected too, because something closing connections before finishing.
I have passed all 3 steps with trying to elevate the nodes after each step.
The 3rd one worked for me.
Thank you Alexey!
