You need to replace all the " ` " marks with a “single quote” in the command, Something in the forum messes up “single quote mark” and throws an error when you run it.
@S0litiare thank you, i’ve notice this and fixed quote, but it does not help as the docker is not running:
docker ps -a | awk ‘{ print $1,$2 }’ | grep watchtower:latest | awk ‘{print $1 }’ | xargs -I {} docker stop {}
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
Tried all possible combinations:
sudo service docker start <-- this command freezes forever (or until cmd+c) nothing happening
sudo service docker stop <-- this command freezes, forever (or until cmd+c) with error:
Job for docker.socket failed.
See “systemctl status docker.socket” and “journalctl -xe” for details.
● docker.socket - Docker Socket for the API
Loaded: loaded (/lib/systemd/system/docker.socket; enabled; vendor preset: enabled)
Active: inactive (dead) since Fri 2019-10-04 11:18:58 EEST; 2h 30min ago
Listen: /var/run/docker.sock (Stream)
Oct 04 00:58:55 raid6 systemd[1]: Starting Docker Socket for the API.
Oct 04 00:58:55 raid6 systemd[1]: Listening on Docker Socket for the API.
Oct 04 11:18:58 raid6 systemd[1]: Closed Docker Socket for the API.
Oct 04 13:45:48 raid6 systemd[1]: docker.socket: Socket service docker.service already active, refusing.
Oct 04 13:45:48 raid6 systemd[1]: Failed to listen on Docker Socket for the API.
Oct 04 13:47:05 raid6 systemd[1]: docker.socket: Socket service docker.service already active, refusing.
Oct 04 13:47:05 raid6 systemd[1]: Failed to listen on Docker Socket for the API.
Oct 04 13:49:18 raid6 systemd[1]: docker.socket: Socket service docker.service already active, refusing.
Oct 04 13:49:18 raid6 systemd[1]: Failed to listen on Docker Socket for the API.
Yesterday i’ve seen tens of thausands of docker watchtower procesess… restart of the server does not help.
Docker stucked.
I can’t start it, i can’t stop it, i can’t uninstall it…
Will try in evening, but today is not that evening, where i would like to spend with docker…
sudo apt-get autoremove -y --purge docker-engine docker docker.io docker-ce
Reading package lists… Done
Building dependency tree
Reading state information… Done
Package ‘docker-engine’ is not installed, so not removed
Package ‘docker’ is not installed, so not removed
Package ‘docker.io’ is not installed, so not removed
The following packages will be REMOVED:
docker-ce*
0 upgraded, 0 newly installed, 1 to remove and 3 not upgraded.
1 not fully installed or removed.
After this operation, 109 MB disk space will be freed.
dpkg: error processing package docker-ce (–remove):
package is in a very bad inconsistent state; you should
reinstall it before attempting a removal
Errors were encountered while processing:
docker-ce
E: Sub-process /usr/bin/dpkg returned an error code (1)
Once the machine is rebooted run docker ps and see if that gives you anything. Since you tried to uninstall and it failed it might throw up an error. That’s OK.
sudo apt-get install docker-engine docker docker.io docker-ce
Package docker-engine is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
docker-ce
E: Package ‘docker-engine’ has no installation candidate
trying other ways…:
sudo apt-get install docker-ce docker-ce-cli containerd.io
Reading state information… Done containerd.io is already the newest version (1.2.6-3). containerd.io set to manually installed.
docker-ce-cli is already the newest version (5:19.03.2~3-0~ubuntu-bionic).
docker-ce-cli set to manually installed.
Recommended packages:
aufs-tools cgroupfs-mount | cgroup-lite pigz
The following packages will be upgraded:
docker-ce
1 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Need to get 0 B/22.7 MB of archives.
After this operation, 91.1 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database … 148179 files and directories currently installed.)
Preparing to unpack …/docker-ce_5%3a19.03.2~3-0~ubuntu-bionic_amd64.deb …
Unpacking docker-ce (5:19.03.2~3-0~ubuntu-bionic) over (5:19.03.1~3-0~ubuntu-bionic) …
Setting up docker-ce (5:19.03.2~3-0~ubuntu-bionic) …
A dependency job for docker.service failed. See ‘journalctl -xe’ for details.
invoke-rc.d: initscript docker, action “start” failed.
● docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Docs: https://docs.docker.com
Oct 04 16:02:25 raid6 systemd[1]: Dependency failed for Docker Application Container Engine.
Oct 04 16:02:25 raid6 systemd[1]: docker.service: Job docker.service/start failed with result ‘dependency’.
Oct 04 18:58:50 raid6 systemd[1]: Dependency failed for Docker Application Container Engine.
Oct 04 18:58:50 raid6 systemd[1]: docker.service: Job docker.service/start failed with result ‘dependency’.
dpkg: error processing package docker-ce (–configure):
installed docker-ce package post-installation script subprocess returned error exit status 1
Processing triggers for systemd (237-3ubuntu10.29) …
Processing triggers for ureadahead (0.100.0-21) …
ureadahead will be reprofiled on next reboot
docker-ce
piece by piece removed all docker and all it’s things arround.
Reinstalled,
Node started, but already 2min. OFFLINE, watching log’s…
This node finished.
Have another with similar problem…
will have to drive tomorrow to the place, as over VPN only ping responds, ssh takes ages to connect and ages to run any of the commands, because of the same problem… probably…
