I’ve noticed that while monitoring ±10 nodes I’ve spending a lot of time clicking on the each satellite info. 10 nodes x 4 satellites = 40 clicks + 80 drags, when viewing on smaller screen
Even if the information screen would be very long, i would prefer to scroll over the single screen, instead of clicking and then dragging the window, and then dragging window back, then click, drag, drag, click, drag, click, click, drag, click… It’s so uncomortable, that I’m doing it on very rare occasions, but would very nice to have it by hand on the same screen as dashboard’s I’ve monitoring quite often
check my tool, work on windows, but if your node is on local network you can use it, just share dashboard to your local network. show all this you wanted. There is also source code, can compil you version as console, then can run on linux also.
