after electrical failure and disk check, there was a problem with trust-cache.json, deleted it, created a new one and noda worked, but the web panel does not show anything, anyone know what to do?
logs seems ok.
Please advise.
Make sure that the service is running:
PowerShell:
Get-Service storagenode*
Please also check the logs for Unrecoverable and/or FATAL errors:
sls "Unrecoverable|FATAL" "$env:ProgramFiles\Storj\Storage Node\storagenode.log" | select -last 10
Also, please check your databases:
If they are ok, and service is running and there is no a FATAL error, then search for “ping satellite failed” but “rate”:
sls "ping satellite failed" "$env:ProgramFiles\Storj\Storage Node\storagenode.log" | sls -NotMatch "rate" | select -last 10
Status Name DisplayName
Running storagenode Storj V3 Storage Node
Running storagenode-upd... Storj V3 Storage Node Updater
sls "Unrecoverable|FATAL" "D:\storjnode\storagenode.log" | select -last 10
D:\storjnode\storagenode.log:215241:2024-08-26T20:47:57+03:00 INFO piecestore upload started {"Piece ID": "TY5HSPP4PDN4
XDJC7LW3V7ZUKQZJE6A42BZU5FATALLDKAWPYNTQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Acti
on": "PUT", "Remote Address": "79.127.226.101:47236", "Available Space": 179399966153}
D:\storjnode\storagenode.log:215252:2024-08-26T20:47:57+03:00 INFO piecestore uploaded {"Piece ID": "TY5HSPP4PDN4XDJC7L
W3V7ZUKQZJE6A42BZU5FATALLDKAWPYNTQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "
PUT", "Remote Address": "79.127.226.101:47236", "Size": 2560}
database check:
bandwidth.db ok
garbage_collection_filewalker_progress.db ok
heldamount.db ok
info.db ok
notifications.db ok
orders.db ok
pieceinfo.db ok
piece_expiration.db *** in database main *** Page 9898: never used Page 11279: never used Page 12401: never used Page 12597: never used Page 12706: never used Page 12910: never used Page 12922: never used Page 12930: never used Page 13431: never used Page 13778: never used Page 14911: never used Page 15386: never used Page 15415: never used Page 15428: never used Page 15930: never used Page 16571: never used Page 17407: never used Page 17720: never used Page 18228: never used Page 19040: never used Page 21627: never used Page 23717: never used Page 23819: never used Page 23941: never used Page 25679: never used Page 25855: never used Page 25964: never used Page 26605: never used Page 26761: never used Page 27030: never used Page 29206: never used Page 30332: never used Page 30442: never used Page 40360: never used Page 40643: never used Page 41280: never used Page 41427: never used Page 42210: never used Page 42242: never used Page 42423: never used Page 42546: never used Page 43174: never used Page 49075: never used Page 49964: never used Page 54844: never used Page 56098: never used Page 57784: never used Page 58411: never used Page 58614: never used Page 58884: never used Page 59197: never used Page 59519: never used Page 59880: never used Page 60021: never used Page 60086: never used Page 60097: never used Page 60209: never used Page 60262: never used Page 60319: never used Page 61046: never used Page 61055: never used Page 61157: never used Page 61268: never used Page 61315: never used Page 62566: never used Page 66237: never used Page 66977: never used Page 67284: never used Page 67353: never used
piece_spaced_used.db ok
pricing.db ok
Error: stepping, database disk image is malformed (11)
reputation.db *** in database main *** Tree 2 page 2 cell 0: 2nd reference to page 8 wrong # of entries in index sqlite_autoindex_reputation_1
Error: in prepare, file is not a database (26)
revocations.db
satellites.db ok
secret.db ok
storage_usage.db ok
used_serial.db ok
used_space_per_prefix.db ok
sls "ping satellite failed" "D:\storjnode\storagenode.log" | sls -NotMatch "rate" | select -last 10
D:\storjnode\storagenode.log:906323:2024-08-27T08:08:59+03:00 ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEs
WESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: write tcp 192.168.0.106:64225->34.150.199.48:7777: wsase
nd: An existing connection was forcibly closed by the remote host.", "errorVerbose": "ping satellite: write tcp 192.168.0.106:64225->34.15
0.199.48:7777: wsasend: An existing connection was forcibly closed by the remote host.\n\tstorj.io/drpc/drpcstream.(*Stream).sendPacketLoc
ked:336\n\tstorj.io/drpc/drpcstream.(*Stream).Close:594\n\tstorj.io/drpc/drpcconn.(*Conn).Invoke.func1:118\n\tstorj.io/drpc/drpcconn.(*Con
n).Invoke:134\n\tstorj.io/common/rpc/rpcpool.(*poolConn).Invoke.func1:126\n\tstorj.io/common/rpc/rpcpool.stackAnnotated:43\n\tstorj.io/com
mon/rpc/rpcpool.stackAnnotate:79\n\tstorj.io/common/rpc/rpcpool.(*poolConn).Invoke:125\n\tstorj.io/common/rpc/rpctracing.(*TracingWrapper)
.Invoke:32\n\tstorj.io/common/experiment.(*Wrapper).Invoke:28\n\tstorj.io/common/pb.(*drpcNodeClient).CheckIn:137\n\tstorj.io/storj/storag
enode/contact.(*Service).pingSatelliteOnce:190\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:156\n\tstorj.io/storj/storag
enode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\
tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
D:\storjnode\storagenode.log:1058870:2024-08-27T11:08:58+03:00 ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kE
sWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: manager closed: closed: read tcp 192.168.0.106:53082->3
4.150.199.48:7777: wsarecv: An existing connection was forcibly closed by the remote host.", "errorVerbose": "ping satellite: manager clos
ed: closed: read tcp 192.168.0.106:53082->34.150.199.48:7777: wsarecv: An existing connection was forcibly closed by the remote host.\n\ts
torj.io/drpc/drpcmanager.(*Manager).manageReader:233"}
D:\storjnode\storagenode.log:1230453:2024-08-27T15:08:59+03:00 ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kE
sWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: manager closed: closed: read tcp 192.168.0.106:58979->3
ed: closed: read tcp 192.168.0.106:58979->34.150.199.48:7777: wsarecv: An existing connection was forcibly closed by the remote host.\n\ts
as i understand here some problem in an database? i don’t understand which one? reputation.db maybe or some before?
Yes, which are not “ok”:
ok, i do db restore, but node can’t start
2024-08-28T07:28:59+03:00 INFO db.migration.26 Add Trash column to pieceExpirationDB
2024-08-28T07:28:59+03:00 INFO db.migration.34 Add suspended field to satellites db
2024-08-28T07:28:59+03:00 INFO db.migration.36 Add joined_at field to satellites db
2024-08-28T07:28:59+03:00 ERROR failure during run {"error": "Error migrating tables for database on storagenode: migrate: v36: duplicate column name: joined_at\n\tstorj.io/storj/private/migrate.(*Migration).Run:212\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).MigrateToLatest:432\n\tmain.cmdRun:100\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "errorVerbose": "Error migrating tables for database on storagenode: migrate: v36: duplicate column name: joined_at\n\tstorj.io/storj/private/migrate.(*Migration).Run:212\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).MigrateToLatest:432\n\tmain.cmdRun:100\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n\tmain.cmdRun:102\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-28T07:28:59+03:00 FATAL Unrecoverable error {"error": "Error migrating tables for database on storagenode: migrate: v36: duplicate column name: joined_at\n\tstorj.io/storj/private/migrate.(*Migration).Run:212\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).MigrateToLatest:432\n\tmain.cmdRun:100\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "errorVerbose": "Error migrating tables for database on storagenode: migrate: v36: duplicate column name: joined_at\n\tstorj.io/storj/private/migrate.(*Migration).Run:212\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).MigrateToLatest:432\n\tmain.cmdRun:100\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n\tmain.cmdRun:102\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
what next?
Seems the database reputation.db was corrupted too much, unfortunately you need to re-create this database from scratch:
thanks, from scratch node started and online, bandwish and disk space also ok.
but suspension and audit all red, if it ok?
ah ok, NVM, it grows up. thank you very much!
Do you mean that you deleted all data instead of the one database?
i follow instuctions, make backup all db files, start node, wait a little bit, stop node, move all db files except reputation.db
Thank you, I was just concerned when you said
I immediately interpreted this as you recreating the node from scratch.
Then I guess everything should be fine.
Apparently I have a similar problem, but without any corrupted db whatsoever.
bandwidth.db ok
heldamount.db ok
info.db ok
notifications.db ok
orders.db ok
pieceinfo.db ok
piece_expiration.db ok
pricing.db ok
reputation.db ok
satellites.db ok
secret.db ok
storage_usage.db ok
used_serial.db ok
“Unrecoverable|FATAL” and “ping satellite failed” searched gave no results.
As it turned out, searching the logs 1 week ago, showed some fatal error.
C:\Program Files\Storj\Storage Node\storagenode_20241107.log:3939110:2024-11-07T05:00:01+03:00 FATAL Unrecoverable error {“error”: “debug: listener closed”, “errorVerbose”: “debug: listener closed\n\tstorj.io/drpc/drpcmigrate.init:17\n\truntime.doInit:6527\n\truntime.doInit:6504\n\truntime.doInit:6504\n\truntime.do
Init:6504\n\truntime.main:233”
Apparently, after leaving the dashboard open for several minutes (or maybe hours? I didn’t really check it), it shows the data properly, but it’s really annoying. My other node shows dashboard properly, with no delays.
Update: Ok, just a couple of minutes, but still, I can’t get why the difference.
у вас не включен storage2.monitor.dedicated-disk: true ?
начиная с версии 1.115.x у меня на Windows OS возникла такая проблема, что веб интерфейс не загружается, если оставить ее открытой на некоторое время то она начинает все отображать.
Помогло отключение # storage2.monitor.dedicated-disk: true
This is related to the fact that this feature is experimental, not all code paths are updated, so the dashboard will show a wrong stat.
Это связано с тем, что эта фича - экспериментальная, не все места обновлены, чтобы информация отображалась корректно.
The dashboard doesn’t automatically refresh. You need to refresh it manually.
Well, that’s the point. Even if I manually refresh, that round thing will keep rotating, but either it takes too long or it won’t refresh at all.
Then you need to check - is the node still running and accessible.
You may use its port for a quick check: http://localhost:28967 (or http://local_ip:28967), it should response.
I use port 28974 and it’s accessible through the Internet, using YouGetSignal. Shall I doubt and check it specifically through LAN?
You need to try to open it as a web page, if it would respond, then the node is at least functioning and can accept requests.
