Web worker is not initialized
Web worker is not initialized.
Browser console is reporting an error: Failed to fetch wasm manifest.
Hello!
Nice to meet you, and thanks for reaching out. Could you please describe what exactly you are trying to achieve here? According to the screenshot, your hostname is http://172.16.253.15:10002. Could you elaborate on that, please?
If you’re trying to run things in a local network, you should execute one of the prepared bash scripts to generate the WASM module and the other helper files, compress them (optional), and put them into the correct folder.
There are already prepared commands for that purpose in the web/satellite/package.json file called wasm or wasm-dev (which skips the compression step). You can run one of those by executing, for example, npm run wasm or npm run wasm-dev. After running one of those commands, you’ll have all the needed files in place.
Thank you in advance!
