Web3 Binance wallet and zkSync Era
I saw Zksync era supported in Binance web3 chains, so I plan to try send some storj to binance wallet next month. Will see if I will be able to swap it to the exchange from binance web3 zksync address
Please check, that they are accept STORJ tokens over zkSync Era, not only ETH/USDT.
I just checked in their app, STORJ tokens are accepted only via L1 (Ethereum).
However, Web3 Binance wallet can receive STORJ tokens over zkSync Era, but you would need to use a bridge to send them to L1 deposit address anyway.
Yes, that I want to try. They also have some sort of web3 swap, so plan is to play around with 1 storj :grin:
Binance only support Etherium on Zksync.
Sorry over read Web3. Storj is not available on the normal wallet via Zksync. But now I want to try Web3 too. At least it’s listed on web3
Edit: I added my StorJ Wallet to Binance Web3- After manual import of the token contract i got them to show up.
Since when do i have to manually claim the transactoin again?
I knew about the 24 hours wait period. but manual claim wasn´t there before. It was automaticly send to my wallet before.
I dont like that and for that i think i change my wallet back to L1. I now have to pay double ETH fee for that one Transaction.
First fee was L2 (few cents) fee if you used era bridge. You can send to different address (e. g. directly to exchange)
Can you please try to do web3 swap? In Binance “web3 mode” on mobile app, the middle bottom button “Trading?” is different and maybe you can swap storj to eth and move it to the exchange as a result.
You can also try bridge storj.
The zkSync people used to subsidize the L1 fee awhile ago, no longer.
If your main goal is to get to L1 yeah you should just stay there, or somehow hold long enough that the 3% bonus is enough to cover the L1 claim fee and then some.
Before that change, it was ok for me with the 24h wait period. Now I changed all to my binance Wallet
It would have been possible. But I would have lost 10% with that process. And 10% is quite a bit
Welp, guess I have to wait for lower fees. I am not spending 35 USD for that
