Hi,
Trying to run storagenode container on synology docker (DSM7).
The container starts and then stops. Error is:
downloading storagenode-updater stdout
22:31:54 --2022-03-25 22:31:54-- https://version.storj.io/processes/storagenode-updater/minimum/url?os=linux&arch=amd64 stderr
22:31:59 Resolving version.storj.io (version.storj.io)... failed: Try again. stderr
22:31:59 wget: unable to resolve host address 'version.storj.io' stderr
22:31:59 http://: Invalid host name.
This is not a DNS issue on the server. DNS works just fine.
I believe this should be a typo or some other error on the image?
Any ideas?
Thanks
Alex
Hello @Slewrate,
I also use Synology and DSM 7 and had exactly the same error as you. → Docker 1.50.4 restarts many times after "unable to resolve host address 'version.storj.io'" - #3 by sembeth
It is recommended in the documentation to use “–restart unless-stopped”. → Storage Node | Storj Docs
So some of my storagenodes could not resolve the DNS and stopped automatically every time. Due to the “–restart unless-stopped” they automatically restarted and finally after a few restarts they were able to resolve and download the updater and storagenode binaries and it worked.
I’m not sure if it has something to do with our DNS or Synology. I use Cloudflare (1.1.1.1) as DNS Server.
