This is my situation
this morning I had to run the repair of the bandwidth.db but I keep getting errors
This is a part of error
2022-02-24T14:59:53.145Z ERROR piecestore download failed {âPiece IDâ: â64I7KGUESJKGUG7GLBJQ6Q4UBJYSKMVUTZBULSTX4ITBU7S35XJQâ, âSatellite IDâ: â12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3Sâ, âActionâ: âGETâ, âerrorâ: âwrite tcp 172.17.0.3:28967->145.40.89.179:52026: use of closed network connectionâ, âerrorVerboseâ: âwrite tcp 172.17.0.3:28967->145.40.89.179:52026: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:322\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:400\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:619\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22â}
2022-02-24T15:01:52.674Z ERROR piecestore download failed {âPiece IDâ: âTYLB5QKTTRJPV3MLDYLJ3CB76QMXDLM4GWG7QGX42TNWNRYUBP6Aâ, âSatellite IDâ: â12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3Sâ, âActionâ: âGETâ, âerrorâ: âwrite tcp 172.17.0.3:28967->135.148.54.71:37918: use of closed network connectionâ, âerrorVerboseâ: âwrite tcp 172.17.0.3:28967->135.148.54.71:37918: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:322\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:400\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:619\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22â}
2022-02-24T15:05:58.374Z ERROR piecestore download failed {âPiece IDâ: âISOQGM377S3ZNTYHYKQUCR3QXQ4GUW36R5IFHGICXFR6B3OHMP5Qâ, âSatellite IDâ: â12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3Sâ, âActionâ: âGETâ, âerrorâ: âwrite tcp 172.17.0.3:28967->135.148.54.72:47740: use of closed network connectionâ, âerrorVerboseâ: âwrite tcp 172.17.0.3:28967->135.148.54.72:47740: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:322\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:400\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:619\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22â}
2022-02-24T15:09:55.592Z ERROR piecestore download failed {âPiece IDâ: âZ3CYBXF5R3WMNSP6FOIVWQKHE6BHQQREEKAZ7J3U5KO7ZBY7TZ3Aâ, âSatellite IDâ: â12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDsâ, âActionâ: âGET_REPAIRâ, âerrorâ: âfile does not existâ, âerrorVerboseâ: âfile does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:73\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:545\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52â}
Most of the errors you posted are quite normal, with the exception of this one.
Thatâs serious. Your node is missing data it should have. Itâs also not directly related to the database repair you did as this would only happen if the piece itself was missing.
However, it is possible that file system corruption could cause both issues. I recommend checking your file system for problems (fsck).
you are right the filesystem has errors, I am trying to fix them
I donât know what to do anymore, I canât understand what is the problem.
This is logs on last 10000 row using this command:
docker logs storagenode -n 10000 2>&1 | grep -E âGET_AUDIT|GET_REPAIRâ | grep failed
2022-02-28T08:05:08.590Z ERROR piecestore download failed {"Piece ID": "KJLSZQPVT5AIRRREDY4F6DWNFLV2YRNQTJP4YIBAETJ4NJRCHL2Q", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.3:28967->168.119.232.255:57846: use of closed network connection", "errorVerbose": "write tcp 172.17.0.3:28967->168.119.232.255:57846: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:322\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:400\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:619\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-02-28T08:06:22.010Z ERROR piecestore download failed {"Piece ID": "BCBZKV45ZUH42JTWTTR2QDNGBMX4W26FDLS4CBSBQ244MSZXZZTA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.3:28967->157.90.234.115:37992: use of closed network connection", "errorVerbose": "write tcp 172.17.0.3:28967->157.90.234.115:37992: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:322\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:400\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:619\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-02-28T08:10:13.791Z ERROR piecestore download failed {"Piece ID": "BZMHW2VI2CS7EPVA5OIUNUURME6INUPCDE56NJCETS74F4LAPH7A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.3:28967->157.90.17.108:36782: use of closed network connection", "errorVerbose": "write tcp 172.17.0.3:28967->157.90.17.108:36782: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:322\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:400\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:619\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-02-28T08:11:31.869Z ERROR piecestore download failed {"Piece ID": "MAX3SVJQXCBOQQYCH6RJN27NURZMEUE6I5PM3V6ZGQ3CWK4FJAQQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.3:28967->5.161.50.62:33078: use of closed network connection", "errorVerbose": "write tcp 172.17.0.3:28967->5.161.50.62:33078: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:322\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:400\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:619\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
search database is locked in logs
I had the database malformed until day 24 of February, then I fixed it.
Since that day no more error mressages on the database.
Blockquote
So, Iâm assuming you have checked your disks using âfsckâ to make sure they are ok - if not thatâs worth a shot.
fsck is OK
Blockquote
Looking at your stats, you have a TCP : Total of 2051ms (that is really bad) which is why I was thinking your node was being Denial of Serviced.
Might be worth checking your Internet Provider Link, and Internet Provider service status to make sure they arenât having issues.
Iâve just replace router by provider, it seems all ok, i donât understand
I can not walk the right way
First day oh March
A part of errors captured in last 10000 rows of log. this errors repeats every 1 hours
2022-03-01T17:47:42.728Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "SY7YVFBEEQOATIMBBCSPIX6QADSD5U5EEHPQV726EAMW4T2ZGFEQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T17:47:42.729Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "JBHUACEFRQHJERLZIVOTZUS4IBEQT7QXXC4PDQ2NPMVAUJGDJOEA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T17:47:42.729Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "STXSSTD44YGNC4AJBQ6WBWVAAVTCKNKUEQQOGOSS4EDLS6NDNPAQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T17:47:42.730Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "TAE25L2MRGY5GDK6LL6HYGXOJJOTQW4W6YCL6JYPMM7R6EVH42VQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T17:47:42.730Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "FMFYLMATNLHNHQWUXT4NJUMRO4DYCKFR6NNONZLMH5W2OIQSHIWA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T17:47:42.731Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "5M7MBMKVX4UW4EKEQKFCYAHVGXNH7RO5TZW67UT2YOWGGGE4CKYQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T17:47:42.732Z ERROR collector unable to delete piece {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "IFE73IN6E5EWFRJYDUASNXHXPW7EA2MLHRUZIVNXV7H6TXOBMCGA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T17:47:42.732Z ERROR collector unable to delete piece {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "3PW6DENAURGSLFHEC2CEIUDJDV2P3IWTO2DLFHYLKA565FTJFPGA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T17:47:42.733Z ERROR collector unable to delete piece {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "3PJH6F2FLGYITN6WT57N26RT5UHTT4JJEMWBT7FZ7V7JAVRH6MYA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T18:47:42.443Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "SY7YVFBEEQOATIMBBCSPIX6QADSD5U5EEHPQV726EAMW4T2ZGFEQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T18:47:42.444Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "JBHUACEFRQHJERLZIVOTZUS4IBEQT7QXXC4PDQ2NPMVAUJGDJOEA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T18:47:42.445Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "STXSSTD44YGNC4AJBQ6WBWVAAVTCKNKUEQQOGOSS4EDLS6NDNPAQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T18:47:42.446Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "TAE25L2MRGY5GDK6LL6HYGXOJJOTQW4W6YCL6JYPMM7R6EVH42VQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T18:47:42.446Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "FMFYLMATNLHNHQWUXT4NJUMRO4DYCKFR6NNONZLMH5W2OIQSHIWA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T18:47:42.447Z ERROR collector unable to delete piece {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "5M7MBMKVX4UW4EKEQKFCYAHVGXNH7RO5TZW67UT2YOWGGGE4CKYQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T18:47:42.447Z ERROR collector unable to delete piece {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "IFE73IN6E5EWFRJYDUASNXHXPW7EA2MLHRUZIVNXV7H6TXOBMCGA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T18:47:42.448Z ERROR collector unable to delete piece {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "3PW6DENAURGSLFHEC2CEIUDJDV2P3IWTO2DLFHYLKA565FTJFPGA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-01T18:47:42.449Z ERROR collector unable to delete piece {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Piece ID": "3PJH6F2FLGYITN6WT57N26RT5UHTT4JJEMWBT7FZ7V7JAVRH6MYA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:103\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:239\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Delete:220\n\tstorj.io/storj/storagenode/pieces.(*Store).Delete:299\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:97\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
Iâll try to check all the stats:
docker logs storagenode 2>&1 | grep GET_AUDIT | grep failed | grep open -c
0
docker logs storagenode 2>&1 | grep GET_AUDIT | grep failed | grep -v open -c
2
docker logs storagenode 2>&1 | grep GET_AUDIT | grep downloaded -c
803
docker logs storagenode 2>&1 | grep ââGETââ | grep failed -c
0
docker logs storagenode 2>&1 | grep ââGETââ | grep downloaded -c
0
docker logs storagenode 2>&1 | grep ââPUTââ | grep failed -c
18
docker logs storagenode 2>&1 | grep ââPUTââ | grep uploaded -c
8442
docker logs storagenode 2>&1 | grep GET_REPAIR | grep failed -c
181
docker logs storagenode 2>&1 | grep GET_REPAIR | grep downloaded -c
11861
docker logs storagenode 2>&1 | grep PUT_REPAIR | grep failed -c
1
docker logs storagenode 2>&1 | grep PUT_REPAIR | grep uploaded -c
4816
