What is wrong with my configuration?
Hello,
I’m trying to setup my second node on the same linux box. I have tried all this:
-p 28968:28967
-p 14003:14003
-e WALLET=“0x”
-e EMAIL=“info@”
-e ADDRESS=“node2.kozow.com:28968
-e STORAGE=“1TB”
–mount type=bind,source="/mnt/storj/storj/node1/identity",destination=/app/identity
–mount type=bind,source="/mnt/storj/storj/node1/storage",destination=/app/config
–name node1 storjlabs/storagenode:latest
-p 28968:28967
-p 14003:14003
-e WALLET=“0x”
-e EMAIL=“info@”
-e ADDRESS=“node2.kozow.com:28967
-e STORAGE=“1TB”
-p 28968:28967
-p 14003:14002
-e WALLET=“0x”
-e EMAIL=“info@”
-e STORAGE=“1TB”
Ports are open on the router like:
-p 28968:28967 \
-p 14003:14003 \
The error it’s:
ERROR contact:service ping satellite failed
I also tried to:
  • Disable firewall.
  • Identity checked correctly: 2 and 3.
  • DMZ the IP on the router.
My setup:
outside world => 28968
router => 28968 => 28967
node machine => docker
-p 28968:28967 \
Thank you.
it because your node wating to connect on 28968 but router configured to switch from 28968 on wan to 28967 on lan, so node not get connection on 28968 change router to 28968 on lan
-p 28968:28967 \ this mean that in doker insode 28967 but outsode 28968
also it is not recomended to open dashboard to uotside world for connection, only inside lan usage.
Yes!!!
It worked, it’s online now. Thank you very much. I can’t connect to the dashboard. Is this correct?
-p 14003:14003 \ ?
dashdoard shold work on 192.168.1.10:14003 in lan, but if you forward it on router you expouse it to connect from outside world, hackers can hack it
I removed on the router, thank you.
It worked with: -p 14003:14002 \
Now, it’s offline again. This node was down for 2 days, may that be why I can’t connect?
My configuration it’s 29868 to 29868 on router and:
-p 28968:28967
-p 14003:14002
-e WALLET=“0x”
-e EMAIL=“info@”
-e STORAGE=“1TB”
check your node2.kozow.com give you your external ip, do you use ddns updater?
do you have node 1 on same ip?
then no need to make separate ddns, and second ddns will be not updated.
Both nodes use ddns on the same ip/machine. I tried using another ddns host but still the same error:
2021-02-24T12:16:27.061Z ERROR contact:service ping satellite failed {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “attempts”: 6, “error”: “ping satellite error: failed to dial storage node (ID: 1XxvnNhpcT2F8eXVnew2uZpYkAmYRkHqpwhq8pGgKYgvbvTJrg) at address node1.casacam.net:28968: rpc: dial tcp 188.26.207.73:28968: connect: connection refused”, “errorVerbose”: “ping satellite error: failed to dial storage node (ID: 1XxvnNhpcT2F8eXVnew2uZpYkAmYRkHqpwhq8pGgKYgvbvTJrg) at address node1.casacam.net:28968: rpc: dial tcp 188.26.207.73:28968: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
My last configuration:
-p 28968:28967
-p 14003:14002
-e WALLET=“0x…”
-e EMAIL=“info@…”
-e ADDRESS=“node1.casacam.net:28968
-e STORAGE=“1TB”
use same ddns no need to use different
If you want to rule out problems with the DDNS service, you can put your public IP in the ADDRESS field and see if that works. Also, watch out that you are not passing curly quotes and hyphens in your run command. I see them in your posted commands, although I know the forum does some reformatting. You can preserve formatting (which will help the community catch any errors) but placing your block of text with three backticks ( ``` ) on the lines above and below the text block.
Here it’s, still doesn’t connect. IP it’s also on DMZ of the router, so all ports are passed, even 14002/14003 from external now (just until I find the problem).
sudo docker run -d --restart unless-stopped --stop-timeout 300 \
    -p 28968:28967 \
    -p 14003:14002 \
    -e WALLET="0x" \
    -e EMAIL="info@" \
    -e ADDRESS="188.26.207.73:28968" \
    -e STORAGE="1TB" \
    --mount type=bind,source="/mnt/storj/storj/node1/identity",destination=/app/identity \
    --mount type=bind,source="/mnt/storj/storj/node1/storage",destination=/app/config \
    --name node1 storjlabs/storagenode:latest
What the command returns
docker ps
node2@node2:~$ docker ps
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/json: dial unix /var/run/docker.sock: connect: permission denied
node2@node2:~$ sudo docker ps
[sudo] password for node2:
CONTAINER ID   IMAGE                          COMMAND         CREATED          STATUS          PORTS                                                NAMES
38d8069a52a0   storjlabs/storagenode:latest   "/entrypoint"   19 minutes ago   Up 13 minutes   0.0.0.0:14003->14002/tcp, 0.0.0.0:28968->28967/tcp   node1
9c145a08f690   storjlabs/storagenode:latest   "/entrypoint"   3 days ago       Up 13 minutes   0.0.0.0:14002->14002/tcp, 0.0.0.0:28967->28967/tcp   node2
Both are running, but the second doesn’t connect. You can see it here:
http://188.26.207.73:14003/
Firewall it’s off too:
node2@node2:~$ sudo ufw status
Status: inactive
sudo docker logs node1 2>&1 | head -n 30
ERROR   contact:service ping satellite failed   {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtkxcs8EjT69tGE", "attempts": 3, "error": "ping satellite error: failed to dial storage node (ID: 1XxvnNhpcT2F8eXVnew2uZpYkAmYRkHYgvbvTJrg) at address 188.26.207.73:28968: rpc: dial tcp 188.26.207.73:28968: connect: connection refused", "errorVerbose": "pite error: failed to dial storage node (ID: 1XxvnNhpcT2F8eXVnew2uZpYkAmYRkHqpwhq8pGgKYgvbvTJrg) at address 188.26.207.73:28968l tcp 188.26.207.73:28968: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\o/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1
2021-02-24T15:08:44.043Z        ERROR   contact:service ping satellite failed   {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiu21tuvgk3vzoA6", "attempts": 3, "error": "ping satellite error: failed to dial storage node (ID: 1XxvnNhpcT2F8eXVnew2uZpYkAmYRkKYgvbvTJrg) at address 188.26.207.73:28968: rpc: dial tcp 188.26.207.73:28968: connect: connection refused", "errorVerbose": "lite error: failed to dial storage node (ID: 1XxvnNhpcT2F8eXVnew2uZpYkAmYRkHqpwhq8pGgKYgvbvTJrg) at address 188.26.207.73:2896al tcp 188.26.207.73:28968: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\o/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tg
This node was down for 2 days.
what about identitie did you signed it with new key from storj? does it has 6 files?
28968
Identity is verified, it give me 2-3 as output. Ports are open as like:
Captura
It works if I start the node with no content on /storage folder. I moved data from a windows node to this linux, I think it have to be anything about that.
