Your node has been disqualified on 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs 12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB . If you have any questions regarding this please check our Node Operators thread on Storj forum.
Hello @saroha,
I’m sorry that your node is disqualified. Please, try to figure out why is it happened to do not repeat the same mistake in the future.
You can use this guide to find out what was the reason:
Unfortunately unlike suspension the DQ is permanent and not reversible or recoverable.
So, to have a node again you need to start from scratch - with a new generated identity, new authorization token and clean storage.
And do not allow it to fail because of the same reason.
