What value should I put for “storage.allocated-disk-space” if I have a 16TB disk?
The operating system is on an SSD, inside the 16TB disk I have the “config” and “identity” folder.
Thank you
Thank you
You must leave at least 10% free, and a little more for the config folder, where the databases are located, they can exceed a terabyte.
How you did so?
Mine way below 50GB together from three nodes 9TB in total.
it was mentioned in another thread, some SNOs had the piece_expiration.db which was in the hundreds of gigabytes, for me it came to around 100 GB
But I think it was an early problem with TTL, I haven’t read any other complaints lately
I remembered wrong, but they take up a bit of space…![]()
But there are also garbage, temp and trash folders…
But not a terrabyte, right?
Not terabytes, but still you have to do the math carefully if everything is on the same hard disk
2 posts were merged into an existing topic: Disk usage discrepancy?
