Well it looks like all 3 of your nodes went down on the same day, so that means your nodes are all in the same location?
They are on different locations. SH-STORJ is in Shanghai; SG-STORJ is in Singapore.
Traceroute result:
root@OneCloud:~# traceroute asia-east-1.tardigrade.io traceroute to asia-east-1.tardigrade.io (35.194.133.253), 64 hops max 1 116.233.108.1 2.707ms 2.501ms 3.039ms 2 61.152.51.57 8.011ms 7.298ms 7.385ms 3 61.152.51.57 7.253ms 7.551ms 7.562ms 4 61.152.24.42 7.093ms 7.526ms 7.577ms 5 202.97.61.86 17.211ms 19.573ms 19.434ms 6 202.97.12.190 5.250ms 2.824ms 2.984ms 7 202.97.25.230 43.942ms 47.389ms 47.535ms 8 * * * 9 108.170.241.33 31.064ms 30.157ms 30.028ms 10 108.170.241.108 44.052ms 44.284ms 43.032ms 11 172.253.64.172 33.123ms 32.999ms 34.350ms 12 * 216.239.41.7 43.041ms 43.887ms 13 * 74.125.252.142 44.700ms 44.920ms 14 209.85.254.145 43.518ms 43.299ms 44.871ms 15 * * * 16 * * * 17 * * * 18 * * * 19 * * * 20 * * * 21 * * * 22 * * * 23 * * * 24 35.194.133.253 42.046ms 40.268ms 42.473ms root@OneCloud:~# traceroute asia-east-1.tardigrade.io traceroute to asia-east-1.tardigrade.io (35.194.133.253), 64 hops max 1 116.233.108.1 2.970ms 2.139ms 2.645ms 2 61.152.51.57 9.960ms 7.179ms 7.449ms 3 61.152.3.133 9.746ms 7.460ms 7.453ms 4 61.152.24.42 6.402ms 7.503ms 7.604ms 5 202.97.57.25 17.453ms 19.476ms * 6 202.97.12.190 4.080ms 3.082ms 2.757ms 7 202.97.25.230 49.208ms 47.722ms * 8 * * * 9 108.170.241.97 32.801ms 31.406ms 32.907ms 10 108.170.241.112 32.858ms 31.074ms 30.247ms 11 209.85.142.203 30.157ms 30.373ms 32.642ms 12 209.85.142.172 42.185ms 41.332ms 41.143ms 13 72.14.233.210 46.761ms 46.052ms 41.608ms 14 108.170.235.231 42.282ms 43.406ms 46.343ms 15 * * * 16 * * * 17 * * * 18 * * * 19 * * * 20 * * * 21 * * * 22 * * * 23 * * * 24 * * * 25 * * * 26 35.194.133.253 41.733ms 42.149ms 42.487ms
It doesn’t appear that your ISP is blocking the satellite, then. Certainly not for ICMP packets anyway.
I am not sure what caused the initial downtime, but if this is a new node, a small amount of downtime within the first month could have a larger impact than on a normal node - fortunately, we will not put a node into suspension for downtime until after the first 30 days has passed.
Has your score on Asia East recovered at all? I think the outage you mentioned on Dec 4 could explain a partial drop in score, and it could explain the 0% score if you were audited shortly after receiving your first piece, and that audit coincided with the outage.
Thanks moby, it is a new node, just created on the last day of Nov. My score is recovering, it is 75% now.
