Why does Web show OFFLINE while dashboard.sh shows ONLINE?
Hi,
I had run the node for almost one month. Yesterday i found I couldn’t connect to Web, so rebooted the machine and docker, but the status on web gui is always OFFLINE. When using “docker exec -it storagenode /app/dashboard.sh”, the status is ONLINE. My storj docker is running on centos, version v0.28.2.
Can anybody shed some light? Thanks!
Try to use Chrome or Firefox. Try to press the Ctrl+F5
I tried Chrome, Safari and Firefox on Mac, IE and Chrome on Windows, but no luck.
Please, try in incognito mode.
Also, please, check your identity: https://documentation.storj.io/dependencies/identity#confirm-the-identity
I don’t know about incognito mode, could you elaborate it?
I tried following and look like the result is right.
[root@localhost ~]#grep -c BEGIN ~/.local/share/storj/identity/storagenode/ca.cert
2
[root@localhost ~]#grep -c BEGIN ~/.local/share/storj/identity/storagenode/identity.cert
3
In the Chrome browser there is an incognito mode. Please try to open a dashboard in it
I got the same result in incognito mode.
Please, press F12, navigate to the console and press the Ctrl+F5, did you see any errors?
no error found. everything looks fine.
Please, give me result of this command:
docker exec -i storagenode wget -qO - localhost:14002/api/dashboard
Do you have more than one node?
I have only one. Here comes the output:
{“data”:{“nodeID”:”xxxxxxx”,”wallet”:”xxxxxxxx”,”satellites”:[{“id”:”xxxxx”,”url”:“satellite.stefan-benten.de:7777”,“disqualified”:null},{“id”:”xxxx”,”url”:“asia-east-1.tardigrade.io:7777”,“disqualified”:null},{“id”:”xxxx”,”url”:“us-central-1.tardigrade.io:7777”,“disqualified”:null},{“id”:”xxxxxxx”,”url”:“europe-west-1.tardigrade.io:7777”,“disqualified”:null}],“diskSpace”:{“used”:4332910080,“available”:800000000000},“bandwidth”:{“used”:14535620608,“available”:10000000000000},“lastPinged”:“2019-12-27T00:17:38.022330051Z”,“lastPingFromID”:“1111111111111111111111111111111112m1s9K”,“lastPingFromAddress”:“”,“version”:“0.28.2”,“allowedVersion”:“0.27.0”,“upToDate”:true,“startedAt”:“2019-12-26T17:51:10.073849903Z”},“error”:“”}
Dashboard is working. Then the problem with a browser. What is your browser?
I tried Chrome, Safari and Firefox on Mac, IE and Chrome on Windows.
Is your port open on the https://www.yougetsignal.com/tools/open-ports/ ?
yes, both 14002 and 28967 are open.
I’m assume that your port is open on the https://www.yougetsignal.com/tools/open-ports/
Please, check in the developer’s console (usually F12), do you have any errors when you refresh the page?
Why do you open port 14002 in your router?
I have found the cause. Looks like it’s due to incorrect system time. Thanks for the help!
I didn’t recognize that it’s not a must. Thanks.
It seems, that there were some changes with dashboard. I mean now execution of that command shows not a json-like string, but pure html “!DOCTYPE html …”. Please could you tell me how to get that json string?
