after a HDD crash i was forced to create a new one.
So i created a new docker container with a second HDD.
After creation the node was running for a day.
Then i´ve got the following message.
Your node has been disqualified on 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
It’s hard to tell from the “huge amount of information” you provide…
My guess is you created a new docker container with your second HDD but used the identity from your old node. That would disqualify the node…
If you start a new node, you need a new identity.
Otherwise the satellite will expect your identity to have all data your old node has. And since the new node doesn’t have the data, your identity gets disqualified.
