Why my dashboard is not working?
Ok, please, try to restart it again.
If still no success, try to reboot the pi.
Have you ran any updates recently?
If you mean update docker yes. If you mean storj container i dont know because i have another container update it automatically
cant restart it. After rebooting still not working
Then please, try to remove the docker and install it again.
sudo docker stop -t 300 storagenode
sudo docker rm storagenode
Then follow this guide: https://docs.docker.com/engine/install/debian/#uninstall-docker-engine
After that install it again: https://docs.docker.com/engine/install/debian/#install-using-the-convenience-script
Then please try to run a container with all your parameters.
I can’t stop it look what it says
I see. Then there is no other options except uninstall the docker and try to install again.
Ok i will try it thanks
i have reintalled docker but i have the same error. If i reinstall the os do i will be able to create the same node with the data without lose? i have the data on a external usb hdd
I solved it reinstalling the os thanks
Sorry for later response. If you have had your identity on the HDD, you should be fine.
I hope you moved your identity from the SD card before formatting.
Yes i have the node with the same identity and for now everything is ok
