After my disk was broken I buy another. Launch all from zero to end. But one sattelite is off. It is us1.storj.io:7777. Is it something wrong from my side or just this satellite is broken?
Everything ok with us1.storj.io:7777
If this is a new node, you may have simply failed your first audit for being offline at the wrong time. Make sure you stay online and it should recover. Though audits are infrequent on new nodes, so it might take a while. If you don’t want to wait for it it may be better to just start over, since this node is very new anyway, you won’t lose much. It’s up to you.
