There are only 3 projects available for each account of 1TB, so will request for more Projects costs more?
No
The initial PRO limits are:
- 3 projects
- 100 buckets per project
- 25 TB storage per project
- 100 TB egress bandwidth per project
- 100,000,000 segments
- 100 request per second rate limit
- 1 write per second to the same object name
- Secure Custom Domains (HTTPS) for Linksharing
However, you may request more. The current hard limit is 80 projects to do not break invoicing (our payment provider has limits on amount of lines in the invoice), so if you plan to implement a multi-tenancy, then please check other options: Options for Multi-tenant Data Partitioning and Isolation - Storj Docs
Isn’t the hard limit set to 10k buckets ?
theoretically there is no limit, but we didn’t test more than 1,000 per project. Also the great number of buckets may affect listing.
