[Workaround] QUIC misconfigured
Continuing the discussion from Binding to a specific interface to stabilize QUIC connectivity:
Evidently, two things need to be true for QUIC to work:
  1. As indicated in the linked post, the interface address must be explicitly included in the server.address; e.g.:
    server.address: 10.0.17.120:28967
  2. The port advertised in contact.external-address and forwarded to the node must be the same. I.e. if you advertise port 28967 in contact.external-address: icecream.example.com:28967 you shall also use the same port in server.address and port forwarding rules/DNAT on your router.
This is on FreeBSD 13.3. YMMV.
So if the external port and internal ports are different, it stops working on some OS?
Because all three of my nodes have different ports:
  1. Windows service
  2. And two containerd (Rancher Desktop) nodes (WSL2 engine)
And the host (Windows) has many interfaces (two physical network ports, but only one is connected), including virtual (Hyper-V, WSL2, Wireguard).
Yes, it broke in the version from the linked post, and I read that the same trickaroo also helped some synology users. Today I was messing with routing, broke it again, in spite of the first workaround being still in place, and narrowed it down to the port…
Tried this on an older Syno and didn’t solve the problem. It’s the only Syno with QUIC missconfig.
It’s likely an ARM-based
Intel Celeron N3050…
