Wrong online-score report on Saltlake satellite
Hi, there’s a wrong online-score report for my node on Saltlake satellite, only on it. Others satellites reports are fine. Could you investigate please ?
You may check when your node was not available:
After that you can analyze your firewall or router logs why it was rejecting connections from these satellites on that time.
Maybe it would be better to rename the online score to sth like satellite connectivity score?
Why?
Is it not self-explanatory enough? You have a bad online score - there is a problem to keep your node online. No?
Because “being online” is not a term with a widely-accepted precise definition. I can “be online” while behind a NAT because my browser words.
Alternatively, if there is such a nice page that describes the methodology of this metric, maybe it should be linked in the dashboard.
Do you maybe have any?
Thanks Alexey for your fast report, here the dashboard and result of PS command.
I’ve checked my router’s log, there’s no incident on the port where node is plugged and no fiber interrupt from my FAI.
1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE
windowStart          totalCount onlineCount
2024-05-02T12:00:00Z         65          59
2024-05-03T00:00:00Z         75          72
2024-05-08T12:00:00Z         70          65
2024-05-09T00:00:00Z         74          73
2024-05-24T00:00:00Z          1           0
121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6
2024-04-29T12:00:00Z        345         344
2024-05-01T12:00:00Z         69          68
2024-05-02T12:00:00Z        374         349
2024-05-03T00:00:00Z        378         354
2024-05-05T12:00:00Z        424         423
2024-05-08T12:00:00Z        377         354
2024-05-09T00:00:00Z        521         519
2024-05-09T12:00:00Z        454         453
2024-05-12T00:00:00Z        403         402
2024-05-22T12:00:00Z         10           9
2024-05-23T12:00:00Z        462         419
2024-05-24T00:00:00Z        497         484
2024-05-25T00:00:00Z        370         369
12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S
2024-05-02T12:00:00Z        472         451
2024-05-03T00:00:00Z        551         516
2024-05-06T12:00:00Z        493         492
2024-05-08T12:00:00Z        579         541
2024-05-09T00:00:00Z        573         571
2024-05-19T12:00:00Z        491         490
2024-05-23T12:00:00Z        383         345
2024-05-24T00:00:00Z        410         402
12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
2024-04-26T00:00:00Z       1027        1026
2024-04-29T12:00:00Z        835         834
2024-05-02T12:00:00Z        965         929
2024-05-03T00:00:00Z       1000         946
2024-05-08T12:00:00Z        935         872
2024-05-17T00:00:00Z        737         736
2024-05-23T12:00:00Z        831         710
2024-05-24T00:00:00Z        979         959
As you can see, your node was not available on these dates. The reason is unknown from the satellites point of view. So you need to check why is it happened.
Any what?؜؜؜؜؜؜؜؜؜؜؜؜
Any suggestion where to took this
I do not have an idea, how to describe it in the one page. We have many pages, each describes the own “metric”, but no one which have the consolidated one. Could you please create a PR??
Usually if I have a network problem or an interruption in storj service, it impacts all the satellites.
I have another node on other port on the same switch, I have no reported incidents with Saltlake.
Mystery…
I meant the page you linked.
Nothing unusual, each satellite is independent from each other, so they audit your node in a different time and with a different frequency. Also your router, firewall, antivirus, ISP, etc. may block “suspicious” traffic from the specific source IP ranges for example.
Oh, I’m sorry, I finally got what do you mean. I thought for some reason that you suggesting to create a page where all metrics are explained together…
I would pass your suggestion to link it on the dashboard to the team
I especially think that there is such a high data rate at the moment on the nodes because of the “great purge” that there must be some ISP blocks totally beyond the control of all of us.
I’ve never seen my online-scoring move on a day-to-day basis like this, it’s inconsistent given the stability of the connection here.
It should go back to normal when the full storage will be rebalanced on all the nodes and it stops yo-yoing :joy:
Have a good day Alexey
